AmandaBrady Posted July 22, 2021 Share Posted July 22, 2021 (edited) Hi All, We are experience a fairly frustrating situation, and after exhausting the avenues I know of, I'm coming here for help. - We have a 34 page layout file, consisting of floor plans, elevations, 3D perspectives, and schedules. - All elevation and 3D cameras are set to update on demand - File has printed perfectly fine in the past, up until adding in the schedules. When we go to print, the print dialogue box opens. Upon trying to load all of the pages for preview, it gets to page 30 and crashes. We can't stop the "automatic preview" button because if we hit cancel, it also crashes. We can't choose any other printer option because again, it can't get past the loading of all of the pages. I've purged the files, did a windows update, and tried printing on the other computers in our office. We're running robust new systems with 3090 cards, drivers up to date. Any insights here that could be helpful? We have a looming deadline and I'd really like to be able to get this thing off the printer! It won't let me attach the layout file here, says the size is too large. Also, we are running x13 Thanks in advance. Edited July 22, 2021 by AmandaBrady Link to comment Share on other sites More sharing options...
rgardner Posted July 22, 2021 Share Posted July 22, 2021 On 7/22/2021 at 5:44 PM, AmandaBrady said: We can't stop the "automatic preview" button because if we hit cancel, it also crashes. Expand One thing to try is to turn the automatic preview off by default. Open another file and unselect it and save. Link to comment Share on other sites More sharing options...
BrianBeck Posted July 22, 2021 Share Posted July 22, 2021 Amanda, Open Preferences and on the Render Panel check the option under Troubleshooting called Manage GPU Residency. This should hopefully allow you to print the entire layout. If not please contact Technical Support with the plan and layout file and we can look into it further. Thanks Link to comment Share on other sites More sharing options...
AmandaBrady Posted July 22, 2021 Author Share Posted July 22, 2021 On 7/22/2021 at 6:19 PM, BrianBeck said: Amanda, Open Preferences and on the Render Panel check the option under Troubleshooting called Manage GPU Residency. This should hopefully allow you to print the entire layout. If not please contact Technical Support with the plan and layout file and we can look into it further. Thanks Expand Thanks Brian, we will try that and see if we can get that to work. Link to comment Share on other sites More sharing options...
AmandaBrady Posted July 22, 2021 Author Share Posted July 22, 2021 On 7/22/2021 at 5:56 PM, rgardner said: One thing to try is to turn the automatic preview off by default. Open another file and unselect it and save. Expand Thanks for that tip - we were able to at least get it to export to a pdf in half the pages at a time. So an improvement for sure. 1 Link to comment Share on other sites More sharing options...
sea_lyons Posted February 27, 2024 Share Posted February 27, 2024 On 7/22/2021 at 5:44 PM, AmandaBrady said: Hi All, We are experience a fairly frustrating situation, and after exhausting the avenues I know of, I'm coming here for help. - We have a 34 page layout file, consisting of floor plans, elevations, 3D perspectives, and schedules. - All elevation and 3D cameras are set to update on demand - File has printed perfectly fine in the past, up until adding in the schedules. When we go to print, the print dialogue box opens. Upon trying to load all of the pages for preview, it gets to page 30 and crashes. We can't stop the "automatic preview" button because if we hit cancel, it also crashes. We can't choose any other printer option because again, it can't get past the loading of all of the pages. I've purged the files, did a windows update, and tried printing on the other computers in our office. We're running robust new systems with 3090 cards, drivers up to date. Any insights here that could be helpful? We have a looming deadline and I'd really like to be able to get this thing off the printer! It won't let me attach the layout file here, says the size is too large. Also, we are running x13 Thanks in advance. Expand Are you still having this issue or was it ever resolved? I'm experiencing the same thing with every semi-large layout file - ready to rip my hair out. Tried both suggestions above to no avail. Link to comment Share on other sites More sharing options...
Gawdzira Posted February 27, 2024 Share Posted February 27, 2024 Which PDF driver are you using? "Chief Architect Save As PDF" is the most reliable. Link to comment Share on other sites More sharing options...
sea_lyons Posted February 29, 2024 Share Posted February 29, 2024 On 2/27/2024 at 8:32 PM, Gawdzira said: Which PDF driver are you using? "Chief Architect Save As PDF" is the most reliable. Expand That's the one I'm using. Link to comment Share on other sites More sharing options...
Michael_Gia Posted February 29, 2024 Share Posted February 29, 2024 On 2/29/2024 at 1:58 PM, sea_lyons said: That's the one I'm using. Expand When this happens I try using "Open System Print Dialogue" at the bottom left of the Print Dialogue box. Then I chose "save as pdf" (on a Mac, but there should be a similar option on a PC?) This uses the system print to pdf feature instead of Chief's pdf printer. Link to comment Share on other sites More sharing options...
sea_lyons Posted March 1, 2024 Share Posted March 1, 2024 On 2/29/2024 at 3:32 PM, Michael_Gia said: When this happens I try using "Open System Print Dialogue" at the bottom left of the Print Dialogue box. Then I chose "save as pdf" (on a Mac, but there should be a similar option on a PC?) This uses the system print to pdf feature instead of Chief's pdf printer. Expand That option is greyed out on my dialog box. Link to comment Share on other sites More sharing options...
