ChiefRoland Posted July 7, 2021 Share Posted July 7, 2021 Hello, The Object Information (e.g., code, manufacturer, description, etc.) for cabinet-embedded fixtures do not display in the Fixture Schedule, even though the fixture itself is listed in the schedule. Does anyone know what I'm doing wrong and/or how I can get this info to display? As always, thank you for your kind responses. Roland Link to comment Share on other sites More sharing options...
Kbird1 Posted July 7, 2021 Share Posted July 7, 2021 did you try not embedding the Sink ? - place it on the floor in front of the Cabinet and open it, and set it's height , then use the CTRL Key to slide it into the Cabinet. Link to comment Share on other sites More sharing options...
ChiefRoland Posted July 7, 2021 Author Share Posted July 7, 2021 Thanks Mick, Kind of funky :-( Because it's an object made to be embedded (a double wall oven), it doesn't render correctly if I slide it into the cabinet opening. Is displays at that back of the opening. So in order to make it display correctly, I have to place it in front of the cabinet, which then it looks off in the plan. I think I'm going to convert the schedule to text, edit it in Word to add the missing info (since I don't see a way to edit in tabular format in Chief) and then paste-special back into the CAD detail. I already tried this, the only thing is that I would have to do this every time I change one of my fixtures. Anyway, thank you for your suggestion. It almost worked ;-) Roland Link to comment Share on other sites More sharing options...
Solution Kbird1 Posted July 7, 2021 Solution Share Posted July 7, 2021 14 minutes ago, ChiefRoland said: Thanks Mick, Kind of funky :-( Because it's an object made to be embedded (a double wall oven), it doesn't render correctly if I slide it into the cabinet opening. Is displays at that back of the opening. So in order to make it display correctly, I have to place it in front of the cabinet, which then it looks off in the plan. I think I'm going to convert the schedule to text, edit it in Word to add the missing info (since I don't see a way to edit in tabular format in Chief) and then paste-special back into the CAD detail. I already tried this, the only thing is that I would have to do this every time I change one of my fixtures. Anyway, thank you for your suggestion. It almost worked ;-) Roland Sorry, I forgot to mention in some cases you have to open the symbol ( not object ) and set the X,Y and/or Z to 0" depending on the object, once dropped on the Floor, other you may not see it in 3D, I was thinking sink but for a wall oven the y maybe 22" or something so it "inserts into the cabinet at the right depth. And for good measure while the symbol is open , re-generate the CAD Block too..... Now save it to your Library , so you don't need to do that all again next week M. Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 7, 2021 Share Posted July 7, 2021 1 hour ago, ChiefRoland said: Hello, The Object Information (e.g., code, manufacturer, description, etc.) for cabinet-embedded fixtures do not display in the Fixture Schedule, even though the fixture itself is listed in the schedule. Does anyone know what I'm doing wrong and/or how I can get this info to display? As always, thank you for your kind responses. Roland FYI it does in X-13, upgrade! Link to comment Share on other sites More sharing options...
ChiefRoland Posted July 7, 2021 Author Share Posted July 7, 2021 Awesome! That worked. Thanks again Mick. I'm glad to hear that's been fixed in X13 Renerabbitt. Thanks! Link to comment Share on other sites More sharing options...
scottharris Posted July 9, 2021 Share Posted July 9, 2021 On 7/7/2021 at 4:03 PM, Renerabbitt said: FYI it does in X-13, upgrade! Here's an image of what I think you are asking for. Schedules can include multiple categories, e.g., cabinets and fixtures in a single schedule Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 9, 2021 Share Posted July 9, 2021 21 minutes ago, scottharris said: Here's an image of what I think you are asking for. Schedules can include multiple categories, e.g., cabinets and fixtures in a single schedule You tagged me Scott but I think you meant to quote the OP. X-12 you could include a fixture in a schedule yes. What the OP is referring to is that in X-12, when a sink is inserted into cabinet, we lose the Object Information Panel in the symbols dbx. In X-13 you can access the symbols Object Info after it is inserted into cabinet. Bravo Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 9, 2021 Share Posted July 9, 2021 26 minutes ago, scottharris said: Here's an image of what I think you are asking for. I don't think that's what the OP is talking about either. As Rene explained, I think he was talking about this (from X13)... Link to comment Share on other sites More sharing options...
