Betobens Posted April 24, 2021 Share Posted April 24, 2021 Hola.. los archivos de Chief Arch. se pueden importar desde Twinmotion. Gracias Link to comment Share on other sites More sharing options...
Chopsaw Posted April 24, 2021 Share Posted April 24, 2021 My Spanish is not so good. Are you wanting to import or export from Chief Architect ? 1 Link to comment Share on other sites More sharing options...
rgardner Posted April 24, 2021 Share Posted April 24, 2021 3 hours ago, Betobens said: Hola.. los archivos de Chief Arch. se pueden importar desde Twinmotion. Gracias Hola buenas noches. Si la pregunta es que si el archivo o .plan pueden pasar a twinmotion la respuesta es si y no. Tienes que exportar como muestra el vídeo arriba un archivo de formato .obj o similar y de allí pueden importarlo a twinmotion. 1 1 Link to comment Share on other sites More sharing options...
Betobens Posted April 25, 2021 Author Share Posted April 25, 2021 Muy bien,... voy a intentarlo de ese modo... gracias Link to comment Share on other sites More sharing options...
Betobens Posted April 25, 2021 Author Share Posted April 25, 2021 Ya lo logre... muy bien.... muchas gracias compañeros por su valiosa colaboración.... saludos Link to comment Share on other sites More sharing options...
rgardner Posted April 25, 2021 Share Posted April 25, 2021 13 hours ago, Betobens said: Ya lo logre... muy bien.... muchas gracias compañeros por su valiosa colaboración.... saludos ¡Qué bien! Bienvenidos al forum! 1 Link to comment Share on other sites More sharing options...
Betobens Posted October 14, 2021 Author Share Posted October 14, 2021 Hello again, .. recently I changed the monitor, and the program at the start time sends me an error message that I do not understand well, will it be that the monitor does not have enough capacity to generate views? I also sent the information of the video card. Thanks Link to comment Share on other sites More sharing options...
Chopsaw Posted October 14, 2021 Share Posted October 14, 2021 I think you need a 900 series GTX card at the very minimum to generate any 3D in X13. https://www.chiefarchitect.com/support/article/KB-03151/message-you-are-using-a-video-card-that-does-not-meet-the-software-s-minimum-requirements.html https://www.chiefarchitect.com/support/article/KB-03146/identifying-the-shader-model-of-your-graphics-card-in-windows.html Not really sure why it changed when you updated the monitor though. Possibly a resolution change as well ? 1 Link to comment Share on other sites More sharing options...
Betobens Posted October 14, 2021 Author Share Posted October 14, 2021 Hola, gracias por la respuesta,... si te comento que en x13 hasta ahora lo estoy trabajando,... y tambien el monitor que estoy usando es una pantalla de Tv de 32"... no se si es eso lo que me esta afectando.... pues quizas un tv no sea lo minmi que un monitor para pc.. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 14, 2021 Share Posted October 14, 2021 The GT 710 does not support Shader Model 6 which is required for x13 new 3D Engine ( Astral ) https://www.techpowerup.com/gpu-specs/geforce-gt-710.c1990 Nvidia also stopped supporting Kepler GPUs ( most 600 and 700 series Cards,) with this weeks Driver Update to 496.13 Not sure if you have a laptop but the 710 can be replaced if in a Desktop.....a few people have used AMD Cards to get Shader Model 6 compatibility. M. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted October 14, 2021 Share Posted October 14, 2021 7 minutes ago, Betobens said: Hola, gracias por la respuesta,... si te comento que en x13 hasta ahora lo estoy trabajando,... y tambien el monitor que estoy usando es una pantalla de Tv de 32"... no se si es eso lo que me esta afectando.... pues quizas un tv no sea lo minmi que un monitor para pc.. I am not sure how many speak Spanish here , best to use English if you can or use Google Translate..... Hello, thanks for the answer, ... if I tell you that I am working on x13 so far, ... and also the monitor that I am using is a 32 "TV screen ... I don't know if that is what It is affecting me .... because maybe a tv is not the minimum that a monitor for pc .. The TV should work fine , but your VideoCard won't with X13 , see my reply above. 1 Link to comment Share on other sites More sharing options...
Betobens Posted October 14, 2021 Author Share Posted October 14, 2021 oh very well, Kbird1... I understand ... and yep it's desktop. Thank you so much.. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 14, 2021 Share Posted October 14, 2021 10 minutes ago, Betobens said: oh very well, Kbird1... I understand ... and yep it's desktop. Thank you so much.. Some people have replaced their 710/720 GT cards with this AMD Card fairly cheaply. AMD RX 560D-4G 4GB GDDR5 https://www.gigabyte.com/Graphics-Card/GV-RX560OC-4GD-rev-10/sp#sp https://www.xfxforce.com/gpus/amd-radeon-tm-rx-560-4gb-14cu-single-fan-2 https://www.techpowerup.com/gpu-specs/radeon-rx-560d.c2990 Mick. 1 Link to comment Share on other sites More sharing options...
Betobens Posted October 14, 2021 Author Share Posted October 14, 2021 Excelent.. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 14, 2021 Share Posted October 14, 2021 4 minutes ago, Betobens said: Excelent.. You are Welcome...good luck. 1 Link to comment Share on other sites More sharing options...
Betobens Posted October 14, 2021 Author Share Posted October 14, 2021 a query, .. I do not know much, ... what do you think is this that I sent you the description, is that the AMD I can not find. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 14, 2021 Share Posted October 14, 2021 1 hour ago, Betobens said: is that the AMD I can not find. No this is a Nvidia GT 730 , it is no good for X13 either try searching for RX 560D-4G or Yeston AMD Radeon RX 560 Graphics Card M. Link to comment Share on other sites More sharing options...
Betobens Posted October 14, 2021 Author Share Posted October 14, 2021 yes very well, ... I understand ... thanks again ... Link to comment Share on other sites More sharing options...
Kbird1 Posted October 14, 2021 Share Posted October 14, 2021 2 minutes ago, Betobens said: yes very well, ... I understand ... thanks again ... You have not done you Forum Signature so I don't know where you are located ? or what other hardware you have , so it is a bit hard to help and most of the links I see are for the USA. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 14, 2021 Share Posted October 14, 2021 19 minutes ago, Kbird1 said: try searching for RX 560D-4G or Yeston AMD Radeon RX 560 Graphics Card M. you could also perhaps find a 2nd hand 900 or 10 Series Nvidia Card, eg a 970GTX or 1070GTX, both will work similar to X12 cameras ( *only 2000 and 3000 series Nvidia cards can use the latest X13 features ) M. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 14, 2021 Share Posted October 14, 2021 just be aware that the RX560 only has 1 HDMI and 1 Display Port so you would be limited to a maximum of 2 monitors. Chief requires that all monitors be attached to the same GPU. Link to comment Share on other sites More sharing options...
Betobens Posted October 14, 2021 Author Share Posted October 14, 2021 ok yes i understand ... Link to comment Share on other sites More sharing options...
