BryanXG
Irregular shaped patio
I can draw the outline of the shape I want (half pear for want of a better description) with Draw Arc and Lines, but I can't get the shape with a polysolid.
How can I convert these lines to a polysolid, or how do I alternatively achieve an irregular shaped patio that I can apply pavers to?
If it's a closed Polyline, you should be able to convert it to a Polyline Solid. With the object selected, is the Close Polyline tool icon visible?
It appears already closed as it is shaded
Should be able to convert to slab, p-solid, or terrain feature, depending on your needs...? then apply any texture...?
Excellent... thank you gents.
Next is to apply a molding to the perimeter (for header bricks)... can this be done to the polysolid, or do I have to duplicate the original polyline and convert it to a molding line?
Try a little copy and paste in place, convert new to simple polyline, convert to molding polyline.
You could also convert to a custom countertop and just apply the molding to the countertop.
I did copy in place/convert to molding, but I do like the countertop idea.
Thank you again, one and all.
    29326
    ernest
    ernest
