ARBDESIGN Posted November 24, 2014 Share Posted November 24, 2014 Does anyone know when changing the window specification to 2 vertical lights can the horizontal bar be adjusted in height. What I mean is that the bottom panels of glass be smaller in height then the top panels of glass. Look forward to your comments. Also want to modify a wide window with 3 panels of glass wide. I want the two closer to the outside to be half as wide as the panel in the middle. How do I do this? Link to comment Share on other sites More sharing options...
tommy1 Posted November 24, 2014 Share Posted November 24, 2014 That setting is in the window DBX. Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 24, 2014 Share Posted November 24, 2014 I would say "yes" but only for creating Custom Muntins. That is completely manual but at least you can then exactly control, shape and location of them. DJP Link to comment Share on other sites More sharing options...
ARBDESIGN Posted November 24, 2014 Author Share Posted November 24, 2014 I just found a helpful video on the CA website about custom muntins. Thankyou Link to comment Share on other sites More sharing options...
glennw Posted November 24, 2014 Share Posted November 24, 2014 You shouldn't need custom muntins to do that. You can adjust the window component heights in the Window Specification dbx...General panel...Component Options...Bottom Component Size. Link to comment Share on other sites More sharing options...
ARBDESIGN Posted November 24, 2014 Author Share Posted November 24, 2014 Hi Glenn, I just tried that and it only seems to show Bottom component size on a double hung window. When using default or triple sliding the only part that is not grey that I can change is left component size. What I have is a 2400mm wide x 2100mm high window sliding in from each side and bottom panel of glass is fixed. Do you have any other suggestions? Link to comment Share on other sites More sharing options...
glennw Posted November 24, 2014 Share Posted November 24, 2014 Adam, Mull a sliding window above a fixed window. Or, Use a double hung and place 2 lites across in the top section only. No lites in the bottom section. Link to comment Share on other sites More sharing options...
kMoquin Posted November 24, 2014 Share Posted November 24, 2014 If you have fixed, casement, or awning windows these type if lites can be accomplished with the "Craftsman" type from the pull down menu. Link to comment Share on other sites More sharing options...
rlackore Posted November 24, 2014 Share Posted November 24, 2014 If you have fixed, casement, or awning windows these type if lites can be accomplished with the "Craftsman" type from the pull down menu. How do you specify the vertical location of the horizontal muntin? Link to comment Share on other sites More sharing options...
kMoquin Posted November 24, 2014 Share Posted November 24, 2014 How do you specify the vertical location of the horizontal muntin? With the "Lites Vertical " entry in the dialog box. Link to comment Share on other sites More sharing options...
rlackore Posted November 24, 2014 Share Posted November 24, 2014 With the "Lites Vertical " entry in the dialog box. Oh, I get it. You can't discretely set the height - it's just CA eliminating the lower muntins. Link to comment Share on other sites More sharing options...
