AbrahamMarufu Posted December 4, 2020 Share Posted December 4, 2020 Good afternoon I am busy with a ptoject in chief architect but i am having trouble putting headers and specifying them... headers also have to overlap the walls and i am struggeling to do that may you plase help me. Link to comment Share on other sites More sharing options...
rgardner Posted December 4, 2020 Share Posted December 4, 2020 21 minutes ago, AbrahamMarufu said: plase help me. Try opening the Window DBX and having a look around. Also master the famous F1 key, it is your friend. Link to comment Share on other sites More sharing options...
joey_martin Posted December 5, 2020 Share Posted December 5, 2020 Set the header and trimmer information in the opening dbx. Link to comment Share on other sites More sharing options...
jasmdesigns Posted January 5, 2021 Share Posted January 5, 2021 sorry in default setting header height doesn't work. we use only 2x10, went in and changed and tell rebuild framing goes back to 2x6 Link to comment Share on other sites More sharing options...
GeneDavis Posted January 5, 2021 Share Posted January 5, 2021 Changed what? Did you look at your defaults for framing? Link to comment Share on other sites More sharing options...
rgardner Posted January 5, 2021 Share Posted January 5, 2021 1 hour ago, jasmdesigns said: sorry in default setting header height doesn't work. we use only 2x10, went in and changed and tell rebuild framing goes back to 2x6 You placed the windows after you changed the default or before? Link to comment Share on other sites More sharing options...
Kiwideziner Posted January 5, 2021 Share Posted January 5, 2021 Change your default settings under framing, if you only use 2x10 just put 2x10 in each of the four ? boxes Link to comment Share on other sites More sharing options...
