Fbgdesign Posted September 18, 2020 Share Posted September 18, 2020 (edited) I have an ASUS ROG laptop to be able to run chief. However, whenever I use a second monitor (HDMI connection) and try and use both screens expanded it will freeze Chief. Has anyone else had that or what causes that to happen? I would have thought a gaming computer would be able to handle graphics on a separate monitor. It has always done this with the past few versions and last few years and with new monitor. Thanks for any advice! This is my computers info on the 'Gaming Center' that comes up. Sorry I am not a techy person! Running Chief Architect X12 Asus ROG GL702VSK Intel Core i7-7700HQ CPU 2.80GHz NVIGIA GeForce GTX 1070 GDDR5 8.0 GB (256 bit) 930GB HD (673 GB available) 12 GB RAM (3.8 available) Edited September 18, 2020 by Fbgdesign Link to comment Share on other sites More sharing options...
Chopsaw Posted September 18, 2020 Share Posted September 18, 2020 Hard to know for sure. You computer should be up to it. I run 3 screens on my 1070. Does this happen with only your current plan file or with others as well ? Link to comment Share on other sites More sharing options...
Fbgdesign Posted September 18, 2020 Author Share Posted September 18, 2020 Pretty much any time on any type of file I try to open in the last few years freezes so I have to use my laptop screen only for Chief and side screen for emails etc only. It especially seems to happen when I ask it to render something but I don't think all the time. I just gave up but trying to now figure out the issue. I just bought a new screen and did it again. I have to Cntl-Alt-Delete and close out chief to get it to do anything when it freezes. I didn't know if there was some hidden setting on something I didn't know about. Thanks! Link to comment Share on other sites More sharing options...
MarkMc Posted September 18, 2020 Share Posted September 18, 2020 Go into the NVIDIA control panel, manage 3D settings, Program Settings, ADD-navigate to add Chief Architect premier X12. IF you are Ray Tracing also add ChiefArchitectRayTracer.exe Then go to Set Up Multiple Displays and make sure that your second display is checked. Lastly it can be worthwhile to set the Windows Power Options to Performance. If that is not a choice you may have to create it. Search the web for instructions on creating a performance power plan. You get there by right clicking on the battery/power icon in the system tray Link to comment Share on other sites More sharing options...
DianneDSC Posted September 20, 2020 Share Posted September 20, 2020 Search the forums for Nahimic service. This is related to sound system. There's been several good posts recently with ideas to deal with this issue. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 20, 2020 Share Posted September 20, 2020 3 hours ago, DianneDSC said: Search the forums for Nahimic service. This is related to sound system. There's been several good posts recently with ideas to deal with this issue. It appears Joe has deleted that thread for some reason Diane I can't find it, at least not at the moment. https://chieftalk.chiefarchitect.com/topic/21770-external-monitors-not-working/ Link to comment Share on other sites More sharing options...
Kbird1 Posted September 20, 2020 Share Posted September 20, 2020 On 9/18/2020 at 7:10 AM, Fbgdesign said: I have an ASUS ROG laptop to be able to run chief. However, whenever I use a second monitor (HDMI connection) and try and use both screens expanded it will freeze Chief. Has anyone else had that or what causes that to happen? I would have thought a gaming computer would be able to handle graphics on a separate monitor. It has always done this with the past few versions and last few years and with new monitor. Thanks for any advice! This is my computers info on the 'Gaming Center' that comes up. Sorry I am not a techy person! Running Chief Architect X12 Asus ROG GL702VSK Intel Core i7-7700HQ CPU 2.80GHz NVIGIA GeForce GTX 1070 GDDR5 8.0 GB (256 bit) 930GB HD (673 GB available) 12 GB RAM (3.8 available) removing Sonic Radar solved it for me, there was no need to remove Sonic Studio or the " Nahimic Service" which is needed for Sonic Studio to work also , though some have reported they had to remove both the Sonic Apps. The Nahimic Service is the Issue , it can also be stopped in the Services App ( Service.msc in the Run Dialog) and configured for manual start only or disabled , at least as a Test. The was also a post in that thread about Nahimic having a White and Black List , and adding Chief to the Blacklist but I did not try that. Edit: think I found it online actually....at Nvidia..... Hi Yes there is known issue between Nahimic 3 and other applications (Maya, Substance Painter, 3D applications using OpenGL ). This primary happens when application is started on secondary monitors. some more research is found here: https://discourse.mcneel.com/t/rhino-freezes-on-secondary-monitor-problem-with-the-nihimic-audio-driver-on-the-motherboard/82258/39 All fixes are just .......uninstall the Nahimic 3 Apps....ie Sonic Radar ( game sound detector) and Sonic Studio (equalizer) For us who don't want accept that solution here is simple fix: Locate this nahimic blacklist ( maybe in a slightly different place on your PC eg if you have a Dell , see below) C:\ProgramData\A-Volute\A-Volute.Nahimic\Modules\Scheduled\Configurator\BlackApps.dat and insert your affected executable application to avoid injecting your application by Nahimic tested on Substance Painter.exe There is no needed to restart PC or Nahimic Service Just save file. 1 Link to comment Share on other sites More sharing options...
DianneDSC Posted September 23, 2020 Share Posted September 23, 2020 On 9/19/2020 at 10:25 PM, Kbird1 said: removing Sonic Radar solved it for me, there was no need to remove Sonic Studio or the " Nahimic Service" which is needed for Sonic Studio to work also , though some have reported they had to remove both the Sonic Apps. Thank you, Mick, for following up on this thread and posting the links. Link to comment Share on other sites More sharing options...
DianneDSC Posted September 23, 2020 Share Posted September 23, 2020 On 9/19/2020 at 10:25 PM, Kbird1 said: Locate this nahimic blacklist C:\ProgramData\A-Volute\A-Volute.Nahimic\Modules\Scheduled\Configurator\BlackApps.dat and insert your affected executable application to avoid injecting your application by Nahimic tested on Substance Painter.exe There is no needed to restart PC or Nahimic Service Just save file. This has worked for me, so far at least. For my laptop Alienware m17r3 the file location is: C:\ProgramData\A-Volute\DellInc.AlienwareSoundCenter\Modules\ScheduledModules\Configurator\BlackApps.dat 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted September 23, 2020 Share Posted September 23, 2020 42 minutes ago, DianneDSC said: Thank you, Mick, for following up on this thread and posting the links. No problem , you too, that should help the Dell Users. When I get a minute I'll post this Info over in the Tips Forum so it doesn't disappear again. (I think Joe may have left the Forum?) Mick 1 Link to comment Share on other sites More sharing options...
