builtright3
External Monitors Not Working
So I have had this ongoing problem with my external monitors not working with 3D views. I attached this video for a demonstration for all to see that might be interested.
https://www.dropbox.com/s/wdt1baoelacbjre/20190315_153050.mp4?dl=0
Things I have tried:
  • Talked to support twice now
  • Tried several different monitors
  • Changes out different types of cables from computer to monitors
  • Updated video card from the NVIDIA site
  • I have also had this problem with two other laptops
At this point I'm just stuck. As you can see in the video I can work around it and that's what I'm doing right now. I think it is something like the problem I was having with the disk drives. That there is just something I'm not understanding or missing. It appears to be software related but I'm just not sure at this point. Very frustrating!
All my computer specs have been updated in my signature so you no what I'm running.
I going to wait and see what kind of responses I get on this video from the forum and then I will send it over to Tech support also if I need to.
Thank You!
in your vid I noticed that when you had the Windows Task Manager opened that I did not see anything showing up under the GPU column. Typically this would show either GPU(0) or GPU(1). It would appear to me that the external monitors are not directly linked to the GTX 1070. Do you have a dock or are you just using the different ports on the laptop to drive the monitors?
also did you set up multiple monitors in the NVidia control panel?
I don't see another option for display monitors to draw from other than the NVIDIA card. Or am I missing something here? Usually there is an on board display card and the NVIDIA card as an option. In this case the NVIDIA card seems to be the only one.
Here is some more information. Not sure if it helps
Capture.thumb.PNG.acac732dd19854a9462eaa3cce6f7f77.PNGCapture2.thumb.PNG.b966bcef6bb99de427e31967875577e3.PNGCapture3.thumb.PNG.4bf43c3d74b37fdf290b24dd2f096806.PNG
Does this answer your question? It looks like the GPU is connected to the GTX 1070
I'm talking about here, did you set this up?
Is there something more I'm missing here to setup that you see?
Nothing there.....
what about the Change resolution TAB?  is each monitor default to it's NATIVE res?  eg 1920x1080 ( or whatever they are)  and also the correct REZ eg 60hz  or 144 for you laptop screen
The HDMI monitor isn't being seen as a TV is it ?     it maybe at 30hz if so
image.thumb.png.c5002951f9b935d6260a36c647046768.pngimage.thumb.png.8ea1ed41ecbb77e843c4062d5e5f5796.png
39 minutes ago, Kbird1 said:
Nothing there.....
1.thumb.PNG.dbf62ceb6805dbf1f8791e4261797b8a.PNG2.thumb.PNG.362bb15b6a3b988de7656f2e00829962.PNG3.thumb.PNG.7da8a768d3b6d7602d1c966dc1d46be4.PNG
14 minutes ago, builtright3 said:
Should I be using the NVIDIA color setting?
Leave it at default , I have a Colour Calibrator and use DisplayCal3 to use calibrated Colour and USE RGB Mode but unless you really need it use default ..at least at 1st...... one issue at a time :) , not that RGB is an issue....just a preference.
Both externals are Using TV Modes (1080p) not a PC Monitor Mode of 1920x1080, did they come with a small driver file/disk? install them if so... ...it's really an .inf file telling Windows how to use them and what modes it has available to be used... (they are perhaps using .inf from Windows Update instead).
**Win10 expects people to hook their Laptops up to a TV via HDMI , so something maybe confused...
then see if there is a PC mode with (NATIVE) next to it after a reboot...
This may have been what Perry was talking about. I can change the external monitors to GPU instead of display like the laptop.
Are the external monitors supposed to be set to GPU instead of display
11.thumb.PNG.289acc55372a56a521b9e697b777fb6b.PNG12.thumb.PNG.a184598f4ba531c5b4cef1863f4411ff.PNG
Set them to PC mode 1st
and then try GPU under scaling if you need to to over-ride any Screen built in scaling modes or try full screen or No Scaling ...
https://support.hp.com/us-en/drivers/selfservice/hp-value-24-inch-displays/7274745/model/16900554
*** add model numbers for your monitors to your Sig. in case someone else can help.... I have no idea which LG you have...
I think your on to something but it doesn't appear to have a 1920 x 1080 under PC
Here are the two monitor descriptions. Im going to look for the software and see what is available for download or update.
re-read 2-3 posts above above...... i'll check photos
*** LG  27MP38VQ-B    https://www.lg.com/us/support-product/lg-27MP38VQ-B#manuals
driver http://gscs-b2c.lge.com/downloadFile?fileId=5I7RCNiwpRFXGxsajOlQ
*** HP  24y https://support.hp.com/us-en/drivers/selfservice/hp-value-24-inch-displays/7274745/model/16900554
driver : https://ftp.hp.com/pub/softpaq/sp80001-80500/sp80260.exe
Not sure if they will help , monitors should be Plug and Play, but from my own experience , if the Man. has a driver use it . As mentioned it not a driver in the true sense , it is a list of resolutions basically so Windows knows what is supported and there is usually a .icm or .icc file too, (with the .inf File) which is the Colour profile for the monitor for Windows too.
Mick.
Mick.
So it is confirmed that the drivers for both monitors I have are current.
Thank You
Edited by builtright3
Clarification
Thank You
Did you install the ones above or did Windows Update do it when you connected them? the Drivers are not always the same , even if the number is the same.
If there is still no Option to Choose a PC resolution , you can try those other setting for scaling  or use Nvidia Control Panel to make a custom Res. for the monitors. The monitor manuals should tell what the default (native)  res. is and what hz it can use , higher is better as far as hz goes if you have a choice but 60 or above is standard , some will also use 72 or 75hz like my Benq.
Yes I downloaded the drivers about a week ago and I did it using your links when I got them just to be sure.
This is the highest resolution numbers go in PC mode
Options are 60hz, 59Hz and 50Hz
77.thumb.PNG.c1cbb893ec7643ee0bfe435df1d69f09.PNG88.thumb.PNG.2be7474fca48be046b96be9c77838dff.PNG
the most common Vertical Hz is 60 ( some are actually 59.9 which Windows 10 sees as 59 , see note in Nvidia Driver PDFs about this ) so either will work.
50hz is not recommended as it could effect some peoples eyes and will also make the mouse a wee bit harder to use ( why gamers all want 120 and 144hz monitors now like your laptop)
However your LG is a Full HD  ie 1920 x1080, Native Res., set that and 60hz, but it's supposed to be able to use 75hz too ( which I do on my BenQ monitors via custom Resolution) , Use the mini displayport here as it is better for higher freq. Hz   (see Spec Sheet attached)
Your HP is also FULL HD  but is only 60hz  see attached .......... (HDMI should work fine for 60hz but use miniDP if there are two)
27MP38VQ Spec Sheet.pdf
HP 24y Product Specifications.pdf
I was always told , when using multiple monitors try to get the same resolution on each one. I set all mine to 1080p native resolution. Never had any problems. They are all 1080p monitors. You can only get 1080p using "HDMI" cables
Although earlier HDMI versions didn't go beyond 1080p, the newer versions support higher resolutions such as 4K (3840x2160) but its the usual minefield of GPU, cable, refresh rate and monitor support.
I currently mix resolutions across 27", 32" & 40" monitors without issue (my work requires various screen sizes) but its luck of the draw these days.
Personally I Use DisplayPort for the BenQ monitors (2160x1440p) to ensure Full bandwidth and colour , I also have a Full HD 23" NEC (1920x1080) hooked up via DVI-D and have no issues.
Most LED Monitors these days use 1080p ( Older CRT monitors could be 1080i too) or higher eg QHD (2K) or 4K , but I was thinking that because the Monitors are using a "TV" mode rather than a PC mode that the issue is likely a Scaling Issue and that the Nvidia Driver isn't using the correct scaling as TVs and Monitors handle scaling differently usually , my Samsung Tv for instance actually has a PC mode to ensure fullscreen picture.  The Fix maybe in the Scaling Options , though I am not sure why there isn't a PC option in the List of Choices to select if there isn't.
Another possible cause would be someone choosing different modes in the Monitor's own menu etc.
I'd check the monitors OSD menu to see if anything there though not likely. Would also open the Intel control just for grins.
Is the HDMI cable hi speed or better (standard will only do 1080i not 1080p)
Edit, had a thought so did a quick search to see if there are issues mixing 144hz with 60hz. I didn't read them but apparently there are stutter issues.
https://duckduckgo.com/?q=problem+mixing+144hz+monitor+with+60hz&t=h_&ia=web
I'd go to notebookreview.com and check the forums there, Asus, owners lounge for specific machine and anything on monitors.
    27881
    AET-Phil
    AET-Phil
