builtright3 Posted September 9, 2020 Share Posted September 9, 2020 What the he** is this? I have never seen this happen before. Anyone got a clue? Thank You Link to comment Share on other sites More sharing options...
Chopsaw Posted September 9, 2020 Share Posted September 9, 2020 Cool. How did you get to that point ? Care to post the plan ? Are the ridges connected ? Link to comment Share on other sites More sharing options...
rgardner Posted September 9, 2020 Share Posted September 9, 2020 1 hour ago, builtright3 said: What the he** is this? I have never seen this happen before. Anyone got a clue? Thank You Wayward attic walls? 1 Link to comment Share on other sites More sharing options...
builtright3 Posted September 9, 2020 Author Share Posted September 9, 2020 I would love to place the plan! Harco.plan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 9, 2020 Share Posted September 9, 2020 You have attic walls on both your 2nd floor and on your attic level. They're conflicting with one another. Get rid of the ones on the attic level. 1 1 Link to comment Share on other sites More sharing options...
builtright3 Posted September 9, 2020 Author Share Posted September 9, 2020 1 minute ago, Alaskan_Son said: You have attic walls on both your 2nd floor and on your attic level. They're conflicting with one another. Get rid of one or the other. You mean just turn off the layer? Link to comment Share on other sites More sharing options...
Chopsaw Posted September 9, 2020 Share Posted September 9, 2020 Just go to the Attic level of plan view and delete the offending walls. Curious how you got to that point though ? As built single level and then added proposed garage with 2 levels ? 1 Link to comment Share on other sites More sharing options...
builtright3 Posted September 9, 2020 Author Share Posted September 9, 2020 I used that eyedropper tool to do the siding at the gables instead of changing out the wall type. I think that's what got me in trouble. Link to comment Share on other sites More sharing options...
builtright3 Posted September 9, 2020 Author Share Posted September 9, 2020 Thanks guy's!!! Link to comment Share on other sites More sharing options...
Chopsaw Posted September 9, 2020 Share Posted September 9, 2020 2 minutes ago, builtright3 said: I used that eyedropper tool to do the siding at the gables instead of changing out the wall type. I think that's what got me in trouble. I doubt that was what caused the extra walls but it is not a good habit to get into as it can cause other issues. Carry on. 1 Link to comment Share on other sites More sharing options...
winterdd Posted September 10, 2020 Share Posted September 10, 2020 On 9/8/2020 at 9:34 PM, builtright3 said: What the he** is this? I have never seen this happen before. Anyone got a clue? Thank You i had this happen about a month ago. i ended up deleting the framing, was time consuming. every time i rebuilt the wall framing it came back. Link to comment Share on other sites More sharing options...
builtright3 Posted September 11, 2020 Author Share Posted September 11, 2020 On 9/9/2020 at 7:42 PM, ChiefUserBigRob said: i had this happen about a month ago. i ended up deleting the framing, was time consuming. every time i rebuilt the wall framing it came back. I went to the attic layer and found that some how it generated two attic walls for each and so I deleted one each and the problem went away. Select on wall and hit tab and you will know what I'm talking about. It should come up with a secondary wall if you have the same problem I'm experiencing. Link to comment Share on other sites More sharing options...
