Designer100
Drive way carport and drive issues
I have issues at the rear of the building with slope up to rear carport. Can anyone assist in having a slow slope up to carport on each end? the exist. carport concrete is around 42" above grade. same as existing bldg
I would appreciate help.
Newell Cheatheam
newell@newellcheatheam.com
CA x12
Moheb Building New.zip
Following....I have a similar project coming up
so any suggestions. You mean use ramp tool
How do I get the mess under each end of the carport?
Yes Joey was saying use the ramp tool with railings turned off and a thick base for the slope.
I personally dont understand your last question?  Do you mean how do you make the base not have a gap???  If that is what you are asking... then... Like your question last week either give it a foundation or give it a thickened floor.  Make it a patio room.
How can I get the ramp on carport to meet level with the carport? Ramp Ideal was good. Also I have colums on rear of carport. how do i get them to show up on floor plan(tried pulling forward, but still does not work)
Thanks
Thanks
Look at the absolute elevations of each and set your ramp to it.
    28415
    HeartAlba
    HeartAlba
  • Similar Content
    • By ericepv
      Rochester, NY based rendering company available for remote work. I am a long time Chief user (currently on X-12 but equipped with earlier versions also) and have worked for many commercial clients and residential clients across the country. You can view samples of my work on my website https://epvisualz.com .
      Please contact me directly at 585-441-5291 or by email: eric@epvisualz.com .
    • By steve_mcdowell
      Looking for design partner for upcoming projects. My previous designer used Chief and he is too busy to take on additional work. Ideally looking for someone who may have building experience in addition to being a designer. Looking for someone who can deliver preliminary floor plans and elevations to facilitate proof of concept, someone who can design to specific standards for ARC review and submission standards. The designer will need to understand page naming conventions and all related requirements for the city of Bend Oregon for streamlined permit submission. Structural drafting and coordination with structural engineers.
      See attached files as example of the type of drawings needed
      A0.01 COVER SHEET.pdf
      A0.02 PLAN NOTES.pdf
      A1.01 SITE PLAN.pdf
      A1.02 MAIN FLOOR PLAN.pdf
      A1.03 LOWER FLOOR PLAN.pdf
      A1.04 FOUNDATION AND LOWER FLOOR FRAMING.pdf
      A1.05 LOWER ROOF AND UPPER FLOOR FRAMING.pdf
      A1.06 UPPER ROOF FRAMING.pdf
      A2.01 EXTERIOR ELEVATIONS.pdf
      A2.02 EXTERIOR ELEVATIONS.pdf
      A3.01 BUILDING SECTIONS.pdf
    • By sascea
      Does anyone know how to change the decimal under the story pole marker lines? I've attached a picture, it's the numbers circled in orange. I would like to get rid of them completely as some of my story pole markers are close together and this takes up extra space.
      Thank you in advance!!
    • By Designer100
      i have been trying to work this rear roof out and cannot seem to close it up.
      I would appreciate anyone assisting me. this is all i like finishing up this project.
      Thanks,
      1411 Plan .zip
    • By Ravenquills
      Hi everyone:
      I am having an issue with a split level. I am using Chief X11.
      The plan i posted does not have foundations since when i add those things get really weird and I think I need to sort out the issue with the levels first or the foundation will never build right. I have a room that is going to be garage however no matter how i define it the door from that room into the main house is above the level of the ceiling. see attached photo. I have also attached the plan. The exterior walls are a sip wall customized according to the manufactures specifications with a layer for the furred interior walls. The total thickness on those walls is 10 5/8" The interior wall is a customized interior wall that is load bearing for use in certain areas of the design.
      6242019 RFH (Shell2).plan
