ACADuser Posted August 9, 2020 Share Posted August 9, 2020 I'm trying to move solids, see attached. The end faces need to be aligned and arranged like the picture. I have tried several views & am having trouble snapping to the corners & moving them into place. Solids.zip Link to comment Share on other sites More sharing options...
DzinEye Posted August 9, 2020 Share Posted August 9, 2020 Use CAD detail from view to accurately place lines you can snap to in the 3D model. Cut and paste/hold position into the 3D model. 1 Link to comment Share on other sites More sharing options...
ACADuser Posted August 9, 2020 Author Share Posted August 9, 2020 Thanks for the tip. I think my issue was not having the section camera capturing the entire object. Link to comment Share on other sites More sharing options...
DzinEye Posted August 9, 2020 Share Posted August 9, 2020 Here you go Solids.zip Link to comment Share on other sites More sharing options...
DzinEye Posted August 9, 2020 Share Posted August 9, 2020 I lined up everything in plan view, then in Elevation view of one of the ends moved everything into position. Didn't know if you wanted small gaps for detail clarity... left a few. Link to comment Share on other sites More sharing options...
SNestor Posted August 10, 2020 Share Posted August 10, 2020 18 hours ago, DzinEye said: Use CAD detail from view to accurately place lines you can snap to in the 3D model. Cut and paste/hold position into the 3D model. "Cad Detail from View"...one of the greatest and most under valued tools in Chief. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 10, 2020 Share Posted August 10, 2020 19 hours ago, ACADuser said: Thanks for the tip. I think my issue was not having the section camera capturing the entire object. Yes. I think this was your problem, because even though I too think CAD Detail From View is just swell, that tool should not be necessary for this. You should already have all the snap point you need. Link to comment Share on other sites More sharing options...
DzinEye Posted August 10, 2020 Share Posted August 10, 2020 33 minutes ago, Alaskan_Son said: because even though I too think CAD Detail From View is just swell, that tool should not be necessary for this. You should already have all the snap point you need True that... except as I suggested in one of my responses, I didn't know if he wanted to maintain some small separation of the components so they show up more clearly in a detail. Link to comment Share on other sites More sharing options...
ACADuser Posted August 10, 2020 Author Share Posted August 10, 2020 Thanks all. Once I got the camera positioned correctly I could move the solids as needed. Mark, the detail of that item was not critical but yes I do separate items to keep lines from disappearing. I have the beams in place now & will be cleaning up the framing. Link to comment Share on other sites More sharing options...
robdyck Posted August 10, 2020 Share Posted August 10, 2020 On 8/9/2020 at 2:04 PM, ACADuser said: I'm trying to move solids, see attached. I believe you have a typo, Alan. Link to comment Share on other sites More sharing options...
ACADuser Posted August 10, 2020 Author Share Posted August 10, 2020 You are correct, Thanks. Find & Replace to the rescue. (thank you Chief) Link to comment Share on other sites More sharing options...
