Schedule Issues
hhdesigner
I'm having trouble with the column width on schedules. I added and deleted some columns, set to auto height and width and all except the comments column size properly.  I have tried searching help etc., and haven't found any information on this problem.  I believe my computer recently updated windows 10, could this be a factor? Have tried restarting as well
Yes, and when I did that all the other columns would go back to one line and the columns would be too wide to fit on my layout completely. If I manually dragged the columns closer, the text wouldn't adjust. It seems to only affect the comments column that I added.
That certainly doesn't look right.  You should still be able to get what you want by adjusting the column widths and/or the overall box width (there is a difference).  If all else fails, post the plan or contact tech support.
Is that a live schedule or did you convert to text to add the Comments column ?  Or maybe the custom ceiling finish details ?
I added the comments column.  I've been looking at videos and searching the training manuals. I think I have a lot to learn about schedules.  Some schedules allow to add a comments column and some don't.  I think on this plan I just renamed another item so I could add the column.  Not sure why comments isn't listed on all schedules, but maybe that's what the notes schedule is for.  It's time I took the time to study up on it instead of trying to do a work around that I may not need. Thanks for all the comments...
You can always post your plan file and have one of the experts take a look.  There is a bug with the software when you convert to text but it is not clear exactly what you are showing. It could be something quite simple or you may have run into an issue with the software.
Even without a plan I can see that the schedule was likely a Room Finish Schedule converted to text since the columns shown and contents thereof cannot be done with a Room Finish Schedule otherwise.  Rooms don't have an Object Information tab which you really need to add the types of notations you want, and so I would recommend you switch to using Notes and a Note Schedule instead.  With some relatively simple macros and a small adjustment to your workflow you can automate everything except for the columns where you want to be adding notations manually, and with Notes, doing so can be done very easily while still keeping the schedule live.
    30101
    pbb17t
    pbb17t
  • Similar Content
    • By MarkMc
      I received a couple of question from folks at and after yesterdays GTM I'm attaching a plan and a layout in a zip file. Consider this something for forensic examination-to use to figure out how you want ot go about things. There are very likely mistakes, I'm certain that some of the label macros need work and in the course of putting this together some unwanted ones may have dropped in from the library..
      There was a request at the meeting for annosets. I agree with Perry and Scott that you need to put together what works for you but this may help get you going. The annosets here are a recent update to mine and may have mistakes yet. Started with something, a year or so later updated it, learned some more, fudged it as I went, now going working on a new and improved revised set. No you do NOT need to change annosets with every release. Yes you can use the same annosets for multiple templates (reference manual). OR you can use different ones. It's a good idea to export them somewhere (like the CA data file) with a date associated for when you muck them up or need to go back or want them somewhere else. I keep a second set that is less used for new construction that is different than my everyday remodel set. Just cuts down on the clutter.
      Label macros included- the principal I'm working with is to use one macro while I work so I know what is going on, then to change all the cabinets on the primary layers to have another macro that works for ordering nomenclature (3 inch increments for example) To get any of the macros out you open the macro management dbx pick it and export- then do the reverse in another plan and import (HIT F1)
      There was a question about the molding warehouse- included some in one room with a note. Don't forget to play with the new drag a profile from the library feature.
      Countertops-no chief will not automatically label finished edges- see the plan, keep some text int there and copy and paste. (maybe someone from the dark side can write a macro for that but I'm not going there.) A few ways to get millwork and other things into a schedule- included one arch block turned sideways to show the problem from using them. couple of odd symbols thingies for the schedules. Included-an architectural block with a wood hood and a blower insert inside it. The blower insert is currently set so you can't really resize it without going into the symnbol DBX and changing things (look in the reference manual and play with it -best way to learn) You can use this to see if the blower you want will fit in the hood the client wants. Glass house view, cross section slider, backclipped elevations. Odds and ends-if you have not seen Scott Harris method of globally changing kitchen cabinets you should check it out. Basically he keeps a couple of cabinets on the side in different door/color/construction. Then picks one and sets as default  (one reason I ONLY use cabinets that respect the defaults even though some things don't AND naturally changing from overlay to inset requires some heavy redesign) There was a mention that 2020 will underline a label if you alter the size of a cabinet from the default. Chief won't. Thing is that 2020 will also underline the label if you add an accessory or a modification to the cabinet so it is NOT saving you from yourself (unless you do those last) File and layout attached, neither is complete, but worth fooling with I think.
    • By CaddCreations
      The lengths of framing members in schedules, i.e. rafters, joists, etc appear to be expressed in fractional inches by default.
      Can that be changed to be expressed in feet and fractional inches.
    • By HCremodel
      I am trying to create a custom texture detail schedule that references an object's texture and displays the assigned texture image. Problem is, I am fairly inexperienced with Ruby/macro in general although I have a very basic understanding. Has anyone created something similar to this, or have suggestions on how to get started with creating this type of custom macro? I am using Interiors 12X
    • By Elvis1111
      I am trying to figure out if there is a way to make a framing schedule for the entire project, and not just wall by wall.
      We are finding that framing schedules do a better job listing out the members and sizes then the material lists.
      Thoughts/suggestions?
    • By SNestor
      Can someone either point me to the answer in the manual...or tell me why my NOTES callout has two numbers.  See attached picture.  I'm sure it's something simple...but, I give up.
