StarHome Posted June 18, 2020 Share Posted June 18, 2020 Our truss designers use a program called "True Build" truss design program from Eagle Metal. When my competitor (who also uses Chief Architect) sends a print to our designers in a PDF format they are able to do a Cad Overlay into the True Build program, but when I send them a print in a PDF format they cannot do a CAD Overlay. The All Star_Kevin & Lisa Yoder prints are the ones that do NOT work, & the FREEDOM_Loren Jones House are the ones that DO work. All Star_Kevin & Lisa Yoder 061820.pdf All_Star_Kevin_&_Lisa_Yoder.plan FREEDOM_Loren Jones House Layout (4).pdf Link to comment Share on other sites More sharing options...
StarHome Posted June 18, 2020 Author Share Posted June 18, 2020 It is downloaded into the truss program and that enables them to trace the walls and roof lines etc. Link to comment Share on other sites More sharing options...
StarHome Posted June 18, 2020 Author Share Posted June 18, 2020 They are leaving for the day let me continue this tomorrow. Link to comment Share on other sites More sharing options...
StarHome Posted June 19, 2020 Author Share Posted June 19, 2020 Not sure how to answer that, except "True Build" said it has to something to do with how we save the layers. Link to comment Share on other sites More sharing options...
joey_martin Posted June 19, 2020 Share Posted June 19, 2020 What PDF printer are you using? Link to comment Share on other sites More sharing options...
StarHome Posted June 19, 2020 Author Share Posted June 19, 2020 PDF Exchange Editor Link to comment Share on other sites More sharing options...
joey_martin Posted June 19, 2020 Share Posted June 19, 2020 Try using the PDF printer included in Chief Architect. Select it from the drop down menu. Link to comment Share on other sites More sharing options...
StarHome Posted June 19, 2020 Author Share Posted June 19, 2020 I am sorry that is what I use to save it. Then when I open it it opens in PDF Exchange editor. Link to comment Share on other sites More sharing options...
BrownTiger Posted June 19, 2020 Share Posted June 19, 2020 Both appear to be fine 1.4, produced by the chief architect.... The one that does work contains xmpmeta stream presumably created by this https://helpx.adobe.com/experience-manager/6-3/forms/developing/xmp-utilities.html BT 1 Link to comment Share on other sites More sharing options...
DzinEye Posted June 19, 2020 Share Posted June 19, 2020 1 hour ago, BrownTiger said: Both appear to be fine 1.4, produced by the chief architect.... The one that does work contains xmpmeta stream presumably created by this https://helpx.adobe.com/experience-manager/6-3/forms/developing/xmp-utilities.html BT Very interesting BT... how'd you find that out? Link to comment Share on other sites More sharing options...
Kbird1 Posted June 19, 2020 Share Posted June 19, 2020 5 hours ago, StarHomeJustin said: Not sure how to answer that, except "True Build" said it has to something to do with how we save the layers. See if PDF Editor Allows you to "Flatten" the layers...... (makes it non-editable basically) OR maybe it is the opposite problem and 1 is flatten and the other not ? found Online...... To flatten an image open it in Microsoft Edge, select print, set the printer to Microsoft print to PDF and save a copy to your HD. I have found that this method does not work with Acrobat reader or internet explorer. OR from the US Court System..... Follow the steps below to "flatten" a completed PDF fillable form: 1. Open fillable form. 2. Add appropriate data. 3. Right click on document and select Print. NOTE: if document opens in Adobe, Select File and select Print. 4. Select the PDF printer. (The Adobe PDF printer is installed automatically with Adobe Acrobat. Numerous free PDF printer drivers are available for download from the Internet.) 5. Select OK. 6. Specify location to save the printed, "flattened" version of the form. 7. Select Save. Link to comment Share on other sites More sharing options...
BrownTiger Posted June 19, 2020 Share Posted June 19, 2020 2 hours ago, DzinEye said: Very interesting BT... how'd you find that out? Years ago I wrote a software to read PDF files.... Link to comment Share on other sites More sharing options...
ACADuser Posted June 20, 2020 Share Posted June 20, 2020 Why not export to CAD & let then deal with a CAD file? Link to comment Share on other sites More sharing options...
