CaptainKelly Posted June 15, 2020 Share Posted June 15, 2020 I am trying to draw a Pergola for a costumer, can anyone give advice as to the easiest way to do this. Link to comment Share on other sites More sharing options...
dshall Posted June 15, 2020 Share Posted June 15, 2020 I use polyline solids drawn in either plan view or elevation and then it is best to convert those to symbols especially if you have decorative ends. 1 Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 15, 2020 Share Posted June 15, 2020 DJP Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 15, 2020 Share Posted June 15, 2020 DJP 1 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 15, 2020 Share Posted June 15, 2020 I use the invisible rail deck tool on the 2nd floor. You can adjust all the settings and the posts are automatic if set up correctly. Create a 2nd floor if you don't have one. Link to comment Share on other sites More sharing options...
kylejmarsh Posted June 15, 2020 Share Posted June 15, 2020 3 hours ago, dshall said: I use polyline solids drawn in either plan view or elevation and then it is best to convert those to symbols especially if you have decorative ends. This is typically the correct answer from what I've found. You can use general framing members and multiple-copy them too but the polylines give more control Link to comment Share on other sites More sharing options...
Kbird1 Posted June 16, 2020 Share Posted June 16, 2020 The Framing Tools do work , the disadvantage is the different "elements" can't be saved to the library for re-use like a PL Solid can. ( unless something changed in X12? ) M. Link to comment Share on other sites More sharing options...
