Treehouse2339 Posted May 17, 2020 Share Posted May 17, 2020 When I import a DWG detail file the text will come in as yellow. is there a way to pick the whole file and change all the text to say black? It is a bit time consuming to click on each text to change the color. d Link to comment Share on other sites More sharing options...
joey_martin Posted May 17, 2020 Share Posted May 17, 2020 Map the layers when you import it. Follow the prompts and you will see where you can place items on specific layers. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 17, 2020 Share Posted May 17, 2020 You can also Turn the ALL_Off Layerset on , then turning on only that Text and group Selecting it ALL , then change the Layer Color as desired. This works but I find not 100% of the time as some Items are not using the Layer for Color - those ones you need to open and set them back to using the Layer for Color. M. Link to comment Share on other sites More sharing options...
VisualDandD Posted May 17, 2020 Share Posted May 17, 2020 Also, if stuff is blocked together in dwg it may not change color. Sometimes you have to unblock and then go into dbx individually and check the box that says color by layer. Link to comment Share on other sites More sharing options...
