DWG TEXT COLOR
Treehouse2339
When I import a DWG detail file the text will come in as yellow.  is there a way to pick the whole file and change all the text to say black?  It is a bit time consuming to click on each text to change the color.
d
You can also Turn the ALL_Off Layerset on , then turning on only that Text and group Selecting it ALL , then change the Layer Color as desired. This works but I find not 100% of the time as some Items are not using the Layer for Color - those ones you need to open and set them back to using the Layer for Color.
    30076
    McCallOfTheWild
    McCallOfTheWild
