Geoff_McNeil Posted May 3, 2020 Share Posted May 3, 2020 Have been away from using Chief X11 for a while and started a new plan from a Template which was working very good. What settings am I missing. Thanking anyone replying in advance. Geoff McNeil Link to comment Share on other sites More sharing options...
dshall Posted May 3, 2020 Share Posted May 3, 2020 It looks like you are using 2 walls and the CASING is set to NOT THROUGH. Please post the plans and somebody will help. Link to comment Share on other sites More sharing options...
rgardner Posted May 3, 2020 Share Posted May 3, 2020 Hard to tell without the plan file but most likely what Scott mentioned. But there is a chance that your wall is not lining up with your foundation wall below? Seeing a portion of an attic wall. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 3, 2020 Share Posted May 3, 2020 If it is two walls bumped against each other , that is not necessary , it is a STD Brick Clad Veneer , 2x4 Wall and can be built into 1 Wall definition. Chief has pre-made Brick 4 and per-made brick 6 Walls to try out or Copy and make your own if needed. M. Link to comment Share on other sites More sharing options...
DzinEye Posted May 3, 2020 Share Posted May 3, 2020 Look for the masonry saw in the Tools pull-down 1 Link to comment Share on other sites More sharing options...
Geoff_McNeil Posted May 3, 2020 Author Share Posted May 3, 2020 Thanks everyone for your replies. It was the Foundation wall. Pulled it back a little and it worked. Now to edit my template. Sill looking for the Look for the masonry saw in the Tools pull-down Ha Ha Ha.(Thanks for the break in my concentration DzinEye) Link to comment Share on other sites More sharing options...
