Windows in 3d Views
Geoff_McNeil
Hard to tell without the plan file but most likely what Scott mentioned.  But there is a chance that your wall is not lining up with your foundation wall below?  Seeing a portion of an attic wall.
If it is two walls bumped against each other , that is not necessary , it is a STD Brick Clad Veneer , 2x4 Wall and can be built into 1 Wall definition.
Chief has pre-made Brick 4 and per-made brick 6 Walls to try out or Copy and make your own if needed.
Thanks everyone for your replies. It was the Foundation wall. Pulled it back a little and it worked.
Now to edit my template.
Sill looking for the Look for the masonry saw in the Tools pull-down  Ha Ha Ha.(Thanks for the break in my concentration DzinEye)
    30076
    McCallOfTheWild
    McCallOfTheWild
