Getting an interior wall and an exterior wall to frame as one wall
LeRoyWells
19 hours ago, solver said:
What's in the .dwg?
If you want someone to look at the plan you need to attach the plan file.
It shows it attached           i want the wall in the box to frame as one wall from left to right  when i touch the wall and hit the framing button and then look at the elevation it shows the left wall seperate from the right wall framing
933-Fluharty Addition.dwg
What he is talking about is when he selects the wall detail for that interior wall, he wants it to include the part of the exterior wall that is attached to it. Chief won't do that as they are different walls.
It could be done I suppose. Use one single wall type over the entire plan and add the veneers using a material region, then manually do the foundation and roof. Too much work for me.
