Michael_Gia Posted April 6, 2020 Share Posted April 6, 2020 Hello All, I want my labels to have a transparent background as opposed to the white box around the text. Is this possible? In the image, the lot numbers have a white box around them. I would like the numbers to have a transparent background. Link to comment Share on other sites More sharing options...
HumbleChief Posted April 6, 2020 Share Posted April 6, 2020 Found this, if your labels are generated by the poly line label dbx. 1 Link to comment Share on other sites More sharing options...
Michael_Gia Posted April 6, 2020 Author Share Posted April 6, 2020 45 minutes ago, HumbleChief said: Found this, if your labels are generated by the poly line label dbx. That was it. Problem solved. Thanks Humble Chief. ...and yes, they were polyline labels. Always learning. Link to comment Share on other sites More sharing options...
Ange822 Posted November 5, 2024 Share Posted November 5, 2024 On 4/6/2020 at 6:43 PM, Michael_Gia said: That was it. Problem solved. Thanks Humble Chief. ...and yes, they were polyline labels. Always learning. Is there a way to make a "text label" only a certain % of transparent background? I am trying to utilize the "text label" within the fixtures so it shows the fixture size when it changes size etc. I used to just use a text box and was able to set the transparency of the background colour, but it doesn't seem to be an option for "text labels"? Fixture "text label" background solid Fixture "text label" background transparent (100% default?) No "text label" only a "text box", with setting the background to transparent 15% thanks in advance! Link to comment Share on other sites More sharing options...
DBCooper Posted November 5, 2024 Share Posted November 5, 2024 Quote Is there a way to make a "text label" only a certain % of transparent background? Nope, it's all or nothing with the automatic labels. You could manually place your own text boxes but that hardly seems worth it just to get some partial transparency. 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted November 5, 2024 Share Posted November 5, 2024 5 hours ago, DBCooper said: Nope, it's all or nothing with the automatic labels. You could manually place your own text boxes but that hardly seems worth it just to get some partial transparency. yet another reason we need layer based fill styles 3 1 Link to comment Share on other sites More sharing options...
