LevisL Posted March 26, 2020 Share Posted March 26, 2020 I just discovered last night that when you set a railing wall to 'Follow Stairs', where the height gets calculated from seems wrong to me. Our Canadian Building Code specifies that the height is to be calculated from the tip/tangent point of the nosing. After sending this to tech. support, they replied to me that Chief calculates it from the back of the tread and sent me this image. Just curious what the IRC/IBC says for you folks in the States? If your code is similar to ours, maybe we can get Chief to change this setting. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 26, 2020 Share Posted March 26, 2020 Code is the same here. Measured from the nosing. Link to comment Share on other sites More sharing options...
dshall Posted March 26, 2020 Share Posted March 26, 2020 CA should fix this..... will you send it in? 1 Link to comment Share on other sites More sharing options...
LevisL Posted March 26, 2020 Author Share Posted March 26, 2020 1 minute ago, dshall said: CA should fix this..... will you send it in? Yes. My case with tech. support is still open. Link to comment Share on other sites More sharing options...
DzinEye Posted March 26, 2020 Share Posted March 26, 2020 1 hour ago, LevisL said: Just curious what the IRC/IBC says for you folks in the States? If your code is similar to ours, maybe we can get Chief to change this setting. Good catch... measured from nose is typical Link to comment Share on other sites More sharing options...
robdyck Posted March 26, 2020 Share Posted March 26, 2020 Here's another railing issue from an old topic. Link to comment Share on other sites More sharing options...
