Wall Guard Molding Questions
ACADuser
I have to add room moldings to several hallways
How / where is the molding default set?
Or how do I use the Object Eyedropper to copy a room molding?
How do you get the molding to be wider than the door opening + casing?
OK I found that the room def holds the molding default for that room type. So I'll change the Hall default room.
I noticed you must add back the base molding when you do this but that complicates the offset needed on the handrails.
I guess you need 2 molding polylines for each molding?
OK, so you can select a room & hit the room molding button again to produce a 2nd room molding polyline.
But I want to have a setback for each door opening or do I need to manually move the molding back for each door?
See attached, the A is the auto side & the M is where I moved the molding end point?
1 minute ago, Alaskan_Son said:
Alan, I think your quickest solution might be to group select your doors, add a casing to provide the offset, generate the Room Molding Polyline for the rail, and then group select the doors and change the casing back.
Very nice !!! :wub:
Genius...works like a charm!  Thanks again Michael!
