decorators3 Posted March 9, 2020 Share Posted March 9, 2020 trying to create multiple roofs... have 3 levels with floor plans done ,,ive attached the elevations - as you can see the roof on sides and rear seem to be ok.. but getting the front has been a nightmare... I have created some roofs but I have not been able to recreate the roof fronts of the house the way it should be. I'm afraid to delete the roofs that are ok in case I cant get them back again. this is my first time with a multiple roofs ..nightmare.. Anybody out there can advise. I've gone into each room and referenced the roof and ceiling over each room.. rear elevation.pdf right side elevation pdf.pdf left side elevation.pdf front elevation.pdf Link to comment Share on other sites More sharing options...
SNestor Posted March 10, 2020 Share Posted March 10, 2020 You will have to post the plan... Link to comment Share on other sites More sharing options...
decorators3 Posted March 10, 2020 Author Share Posted March 10, 2020 how do I post my plan Link to comment Share on other sites More sharing options...
Rpadge Posted March 10, 2020 Share Posted March 10, 2020 Attach the .pln file Link to comment Share on other sites More sharing options...
SNestor Posted March 10, 2020 Share Posted March 10, 2020 3 hours ago, decorators3 said: how do I post my plan Save the plan. Close the plan file....maybe save it to your "desktop". Then...in a new post drag the file into the "attach" area of the post. Link to comment Share on other sites More sharing options...
decorators3 Posted March 10, 2020 Author Share Posted March 10, 2020 plan attached I think i fixed some of the issues but not all. roofs can be very intricate....oh oh says file too big Link to comment Share on other sites More sharing options...
DzinEye Posted March 11, 2020 Share Posted March 11, 2020 You need to zip it Link to comment Share on other sites More sharing options...
SNestor Posted March 11, 2020 Share Posted March 11, 2020 On 3/10/2020 at 10:20 AM, decorators3 said: plan attached I think i fixed some of the issues but not all. roofs can be very intricate....oh oh says file too big Strip the plan...or, make a copy of the plan and remove everything you can from it. All we need is walls and the roof. You can remove cabinets, doors etc. Might help... You still may have to "zip" the file to get it to the size required. Link to comment Share on other sites More sharing options...
decorators3 Posted March 11, 2020 Author Share Posted March 11, 2020 ...thank you... trying to see if my roof is done properly mc inty .zip Link to comment Share on other sites More sharing options...
SNestor Posted March 11, 2020 Share Posted March 11, 2020 Just now, decorators3 said: ...thank you... trying to see if my roof is done properly mc inty .zip The file doesn't work. You need to close the plan in Chief before zipping the file. If you have the file open...and you go into file explorer and zip the file...it won't work. Close the file in Chief first. Link to comment Share on other sites More sharing options...
Doug_N Posted March 11, 2020 Share Posted March 11, 2020 The best way to create a file that can be uploaded directly is to use the backup utility built into Chief Architect. Test File for Upload.zip Link to comment Share on other sites More sharing options...
Doug_N Posted March 11, 2020 Share Posted March 11, 2020 How to create an upload file without the problem of closing the file first. https://1drv.ms/v/s!Am8Ktm_KVQE5golbHGG1VB1Uw8Bxzg 1 Link to comment Share on other sites More sharing options...
SNestor Posted March 11, 2020 Share Posted March 11, 2020 5 hours ago, Doug_N said: How to create an upload file without the problem of closing the file first. https://1drv.ms/v/s!Am8Ktm_KVQE5golbHGG1VB1Uw8Bxzg Excellent suggestion Doug! Link to comment Share on other sites More sharing options...
Doug_N Posted March 12, 2020 Share Posted March 12, 2020 Thanks Link to comment Share on other sites More sharing options...
