builtright3
Site Plan Dimensions
I typically just put in text for the dimension numbers around the perimeter of the house because I think it's a cleaner look without the dimension lines but it takes a little extra time to do it like that.
Is there a way to do dimensions and then not show the dimension lines? I never really thought to ask the question because Im sure the answer is no but what the heck, im asking anyway.
Select your terrain poly line and click show length and angle.  All sides will show up.  The downside is all have to be in the same location so for example above the line preference is set on the upper line the dimension shows above the polyline on the outside of it,  the lower shows inside the polyline and the same on the sides one outside one inside.  Most of the times not an issue but I had one recently I had to manually place text that showed the line.
I have not done this personally but another option is to do a leader text line with the macros for show length and show angle if you needed to place it remotely.  Then you can “hide” the arrow and line if you want by changing line style and arrow color.
Wall Labels with or without a macro would work fine for that.
Thank You!
So it shows up here with using a Macro but it still shows up as the default label in the plan. What am I doing wrong? Any idea?
Also, I would need it to show up as feet and inches.
Are your wall labels turned on ?
Yes, but the custom macro I put in doesn't show up.
Its interesting that we can turn off the dimension number but cant turn off the dimension lines and not the number.
In Plan View.    Walls, Labels  layer    that is really odd.
It seems in X12 the label doesn't show like it does in X11 unless you take it off automatic ie use Specify.....
So are we talking about X11 or X12 because your screen shot shows the label set to "Specify"
Maybe post your plan file or a test plan showing the same behaviour.
Not at my computer.  Can you change your line style to the blank line and your arrow to background color?
Yes that is also a possibility.  There is also an arrow style without a tip.
Thanks guy's!
I think I will stay with what I'm doing for now until Chief comes out with a better dimension editing dialog box. Too much work to save a minute or two. Probably not much demand for it. I appreciate the effort.
Chopsaw's idea works pretty well actually and is automatic if setup in the Plan Defaults  ( setup in New Plan Template too ) , the dimension is there from the moment you draw the wall.
As you can see it even works for interior Walls.....
image.thumb.png.53a33c78b90bbbbdc5fc4ffd5bb6be33.pngimage.thumb.png.796c3c0b6dd205b4f7c18dad90893c8b.png
It is possible that you did a really good job of placing your manual text and the wall labels are directly underneath.
Thank you very much! This is very helpful.
Thank you! Working good!
    28439
    JennieT
    JennieT
