Create a concave space of this room
apexchris
What software are you using and do you have a plan file that you have started on ?  Maybe draw it out in 2D with a few traditional type sections with the details and one of the experts will try to help out.
Welcome to ChiefTalk
2 hours ago, apexchris said:
But Box window will end with a pop-out exterior wall ... what if i don't want pop-out exterior wall ....
how should i accomplish ?
Sounds like you're saying you essentially want an extra thick wall (24"+) with a window niche in it?
If so, then there's a couple of different ways to achieve.  Verify that's what you want to do and a process can be explained.
34 minutes ago, apexchris said:
Hello,
a Pass-through window is fine ...... should i raise the floor or just put a polyline solid ?
You can use the Pass-Through Frame Setting   , uncheck Wall width and set it to the required depth to reach the exterior Wall
image.thumb.png.ff5ceeee135027218ee4ea37b6930573.pngimage.thumb.png.89d86f3d88beabb10e92bffcc44fdaf6.png
image.thumb.png.a404af451b81f7a941db10c1e1e01aee.png   The Plan to look at Pass-Through as a Box Window.plan
    32919
    scottdanville
    scottdanville
