KatherineD Posted January 16, 2020 Share Posted January 16, 2020 Hi I am having trouble. I go to my library browser and choose a counter top material, then when it is applied to the counter it does change the color, but to just a solid, rather than the material I just chose. No pattern. Also, when I try to use the roller to color my cabinets, in order to get a stain affect, it just comes out solid. Is there something in my default settings that I need to adjust? Thanks! Link to comment Share on other sites More sharing options...
KatherineD Posted January 16, 2020 Author Share Posted January 16, 2020 Also, I changed the backslash on the cabinet to a tile material that I selected from the library, and it doesn't show up. Just still the same wall color. Link to comment Share on other sites More sharing options...
KatherineD Posted January 16, 2020 Author Share Posted January 16, 2020 7 minutes ago, solver said: Welcome It's helpful to know what software you are using as it changes from version to version. It helps others to have this info in your signature so it's always available. Please see this topic for a signature how to. https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk I absolutely do not understand Textures & Patterns. Is it in one of the videos? I'm having the same problem with the backsplash, in that it is just a solid color, rather than the pattern I chose. Link to comment Share on other sites More sharing options...
KatherineD Posted January 16, 2020 Author Share Posted January 16, 2020 I'm using Chief Architect Premier x11 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 16, 2020 Share Posted January 16, 2020 Katherine, What render mode are you using for the views that don't show what you want? What views are you having trouble with? Perspectives or Elevations? This is why posting a picture and even better the plan will get you better answers. Link to comment Share on other sites More sharing options...
rgardner Posted January 16, 2020 Share Posted January 16, 2020 Hi Katherine Welcome to the forum. Looks like you are newer. It really helps as mentioned above to include your software version and some basic info on your hardware in your signature line as it will get you more help when the guys can see that info and not have to ask for it. There are some amazingly talented guys on here who are super generous with their time but it is also limited so if they are browsing through and trying to help people lots of times they do not have the time to ask, what software version do you have, what is your video card, etc., etc. That all being said sounds like your in a rendering mode with textures that don't work in that mode (such as vector view) if so try changing to standard or PBR view first. Otherwise you may have your textures toggled off. In the same button where there is the cross section slider, toggle shadows there is also a toggle textures on and off button. Try that. Hope it helps. Link to comment Share on other sites More sharing options...
Dermot Posted January 16, 2020 Share Posted January 16, 2020 See if some of these training videos will help: https://www.chiefarchitect.com/videos/watch/36/applying-materials-colors-and-textures.html https://www.chiefarchitect.com/videos/watch/1541/cabinet-materials-changing-and-adjusting.html?playlist=102 Or these help articles: https://www.chiefarchitect.com/support/category/8/materials.html Link to comment Share on other sites More sharing options...
KatherineD Posted January 16, 2020 Author Share Posted January 16, 2020 I tried some of the tips and online information about this topic. I was able to create a pattern for the back splash, but the texture and color of the material does not come through. Same with the counter top and the cabinets, and all the other materials. It looks like a cartoon, which is what we were trying to get away from, when we decided to try this program Link to comment Share on other sites More sharing options...
Dermot Posted January 16, 2020 Share Posted January 16, 2020 You are using a vector view for your rendering technique. Vector views will only show solid material colors with line patterns on top of them. If you want to see a more photo-realistic view, you should use either the standard or physically based (PBR) rendering technique which will show textures on your materials. Here is a video on rendering techniques: https://www.chiefarchitect.com/videos/watch/6150/rendering-techniques.html?playlist=102 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted January 17, 2020 Share Posted January 17, 2020 11 hours ago, KatherineD said: I tried some of the tips and online information about this topic. I was able to create a pattern for the back splash, but the texture and color of the material does not come through. Same with the counter top and the cabinets, and all the other materials. It looks like a cartoon, which is what we were trying to get away from, when we decided to try this program Use the Cameras on the Perspective Cameras Menu/Icon which use the Standard Camera, not the Orthographic Cameras Menu which Use Vector View by default. Once in Standard View you can also switch the Render Type to Physical Based Rendering (PBR for short.) https://www.chiefarchitect.com/videos/watch/2426/ M. Link to comment Share on other sites More sharing options...
