ACADuser Posted December 6, 2019 Share Posted December 6, 2019 First, where is the default for the material of the Wall Bridging Material? What material do I use to get steel-like material? Is it possible to create Steel wall blocking? Or just 'C' Channel Blocking? Link to comment Share on other sites More sharing options...
robdyck Posted December 6, 2019 Share Posted December 6, 2019 I think it is. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 6, 2019 Share Posted December 6, 2019 2 hours ago, ACADuser said: First, where is the default for the material of the Wall Bridging Material? Framing Defaults>Materials 2 hours ago, ACADuser said: What material do I use to get steel-like material? Steel, Steel Stud 16" OC, etc. That's really subjective. 2 hours ago, ACADuser said: Is it possible to create Steel wall blocking? Or just 'C' Channel Blocking? Yes. Just set the Bridging material type to U-Channel. Link to comment Share on other sites More sharing options...
RickyP Posted December 6, 2019 Share Posted December 6, 2019 I would really like to be able to edit the wall bridging material also. The default is 38mm lumber and in New Zealand the minimum is 45mm lumber, so every wall frame requires manual editing. The facility to specify the number of rows of blocking and the spacing would be great also. Our Building Code requires bridging at 800mm CRS so every frame has a minimum of two rows. It is really a Chief Architect software development issue. Link to comment Share on other sites More sharing options...
ACADuser Posted December 6, 2019 Author Share Posted December 6, 2019 Thanks, fellas. That's exactly it Rob. Michael, Just to be clear, Defaults>Framing>materials It says roof? See attached. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 7, 2019 Share Posted December 7, 2019 On 12/6/2019 at 8:59 AM, robdyck said: I think it is. didn't you accuse me of making posts like this last week ? M. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 7, 2019 Share Posted December 7, 2019 On 12/6/2019 at 9:46 AM, RickyP said: I would really like to be able to edit the wall bridging material also. The default is 38mm lumber and in New Zealand the minimum is 45mm lumber, so every wall frame requires manual editing. The facility to specify the number of rows of blocking and the spacing would be great also. Our Building Code requires bridging at 800mm CRS so every frame has a minimum of two rows. It is really a Chief Architect software development issue. I do agree as it happens but I'd suggest you join the Beta Program and make a Feature Request ..... 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted December 7, 2019 Share Posted December 7, 2019 On 12/6/2019 at 10:21 AM, ACADuser said: Thanks, fellas. That's exactly it Rob. Michael, Just to be clear, Defaults>Framing>materials It says roof? See attached. Not sure why that always says Roof but that is the one..... then it doesn't matter if you change the Bridging Default "Type" , in fact if I change it to U-Channel the Bridging disappears from a 3D view....whether I use the Steel 16 OC stud or a Metal Framing material of my own, still there in the Wall Detail though.. Link to comment Share on other sites More sharing options...
ACADuser Posted December 8, 2019 Author Share Posted December 8, 2019 OK, I changed my material but the default bridging SIZE illudes me. I used "Steel-Box" instead of U or C channel. I can change it in the 3D view by selecting it, but where is the default setting for bridging size? Link to comment Share on other sites More sharing options...
Kbird1 Posted December 8, 2019 Share Posted December 8, 2019 3 hours ago, ACADuser said: OK, I changed my material but the default bridging SIZE illudes me. I used "Steel-Box" instead of U or C channel. I can change it in the 3D view by selecting it, but where is the default setting for bridging size? There isn't one until the Wall Bridging is built AFAIK , you have to open the DBX for it on each wall and change it ...... RickyP (above) has started a Suggestion for that and being able to setup more than one row and their spacings ...so add you vote too please.... https://chieftalk.chiefarchitect.com/topic/24497-more-wall-bridging-editing-defaults/ M. 1 Link to comment Share on other sites More sharing options...
robdyck Posted December 9, 2019 Share Posted December 9, 2019 If this were my plan, I wouldn't use the bridging tool. I don't trust it to stay in place. I've had too many issues of bridging behaving twitchy and messing up a completed wall framing detail. I use the General Framing instead. Chief leaves that one alone so I get to be in control of how it behaves. You can still place it on the bridging layer, adjust it's type, material, etc. 2 Link to comment Share on other sites More sharing options...
robdyck Posted December 9, 2019 Share Posted December 9, 2019 22 hours ago, Kbird1 said: There isn't one until the Wall Bridging is built AFAIK , you have to open the DBX for it on each wall and change it ...... RickyP (above) has started a Suggestion for that and being able to setup more than one row and their spacings ...so add you vote too please.... https://chieftalk.chiefarchitect.com/topic/24497-more-wall-bridging-editing-defaults/ M. Shouldn't you be able to select all the bridging in plan view (on a single floor) and adjust the size for all the bridging at the same time? Link to comment Share on other sites More sharing options...
robdyck Posted December 9, 2019 Share Posted December 9, 2019 On 12/7/2019 at 10:57 AM, Kbird1 said: didn't you accuse me of making posts like this last week ? M. I know, I know! My phone rang and I never got back to this. I was going to add a few screenshots with some of the settings. Luckily several others have added their expertise to this topic! Link to comment Share on other sites More sharing options...
Kbird1 Posted December 9, 2019 Share Posted December 9, 2019 22 minutes ago, robdyck said: Shouldn't you be able to select all the bridging in plan view (on a single floor) and adjust the size for all the bridging at the same time? Yes , shouldn't be an Issue actually , I usually just do it as I check the Wall Detail(s) though. Your Idea of using General Framing maybe better though as there seems to be some quirks for sure , your idea actually makes me wonder if a Room Molding Poly Line with the U-Channel might work even better ? ( more automated ) M. Link to comment Share on other sites More sharing options...
robdyck Posted December 9, 2019 Share Posted December 9, 2019 Just now, Kbird1 said: Yes , shouldn't be an Issue actually , I usually just do it as I check the Wall Detail(s) though. Your Idea of using General Framing maybe better though as there seems to be some quirks for sure , your idea actually makes me wonder if a Room Molding Poly Line with the U-Channel might work even better ? ( more automated ) M. That'd certainly be a faster way to get it to show up in 3D views, it just wouldn't be in a wall detail. Depends on the type of drawings being provided I guess. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 9, 2019 Share Posted December 9, 2019 3 minutes ago, robdyck said: That'd certainly be a faster way to get it to show up in 3D views, it just wouldn't be in a wall detail. Depends on the type of drawings being provided I guess. That's true , it wouldn't be seen as "framing" in a schedule etc ......I haven't tried it, was just a thought as I typed, so not sure if the Layer can be turned on in a Wall Detail or not? M. Link to comment Share on other sites More sharing options...
robdyck Posted December 9, 2019 Share Posted December 9, 2019 I also am getting some unpredictable behavior when changing the wall bridging. Auto built bridging: edited wall briding to u channel: Every wall deatil shows continuous bridging, but in 3D it only displays in one stud space. That's odd. Link to comment Share on other sites More sharing options...
ACADuser Posted December 9, 2019 Author Share Posted December 9, 2019 What happens to the framing if you need to move the wall? Will General Framing move with it? Link to comment Share on other sites More sharing options...
robdyck Posted December 9, 2019 Share Posted December 9, 2019 The U-channel is also upside down and that can't be changed with the bridging tool AFAIK. Instead, I used a gen framing and it is oriented correctly. But it doesn't show up in plan view and it must be drawn in every wall detail. Copy-paste doesn't work for this. Link to comment Share on other sites More sharing options...
robdyck Posted December 9, 2019 Share Posted December 9, 2019 3 minutes ago, ACADuser said: What happens to the framing if you need to move the wall? Will General Framing move with it? Nope. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 9, 2019 Share Posted December 9, 2019 4 hours ago, robdyck said: I also am getting some unpredictable behavior when changing the wall bridging. Auto built bridging: edited wall briding to u channel: Every wall deatil shows continuous bridging, but in 3D it only displays in one stud space. That's odd. Yep , not good , same thing exactly was happening to me , leave it set to lumber and all is well in 3D though , steel box also works but there is no difference really. M. Link to comment Share on other sites More sharing options...
robdyck Posted December 9, 2019 Share Posted December 9, 2019 Seems to me the simplest would be a molding p-line for 3d views and a CAD box for wall details or a gen framing member for each wall detail where it matters. Which leads to the real question...what type of drawings and how many need to show the wall bridging? @ACADuser Alan, would you be able to shed a bit more light onto your project details: where and why you need to show it? Perhaps you could share a few screenshots of the project drawings where the bridging needs to be displayed. Link to comment Share on other sites More sharing options...
ACADuser Posted December 9, 2019 Author Share Posted December 9, 2019 Rod, Thanks for the interest. The current project only needs a small area detailed as the main building is within the "Metal Building" and the shell is by others. I have been receiving more requests for wall detail for the next project. 16000 sq ft with CMU exterior walls & metal frame interior walls. The current project may require more interior walls detailed but for now, I'm not providing them. The Entry at the side of the building is all LGF framing so they want the details for the structural envelope. Link to comment Share on other sites More sharing options...
ACADuser Posted December 9, 2019 Author Share Posted December 9, 2019 In fact, I'm having to detail these walls which are not walls in Chief, but are P-solids. I wish they could be walls so I could auto frame them. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 9, 2019 Share Posted December 9, 2019 3 hours ago, ACADuser said: In fact, I'm having to detail these walls which are not walls in Chief, but are P-solids. I wish they could be walls so I could auto frame them. I guess I need to ask why they aren't walls ....it isn't obvious at least to me.... M. Link to comment Share on other sites More sharing options...
