winterdd Posted December 2, 2019 Share Posted December 2, 2019 does anyone have an easy way they calculate their offsets for drop ceilings. the framing needs to start at the wall. i got one room fixed after about a half hour of trial and error but there has got to be an easier way. Link to comment Share on other sites More sharing options...
Electromen Posted December 2, 2019 Share Posted December 2, 2019 I've done it by opening Room Specifications > Ceiling > Ceiling Finish > Edit > Ceiling Finish Layer > Insert Above > Thickness (set depth) > Texture > Insulation Air Gap Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 2, 2019 Share Posted December 2, 2019 Please read this Knowledge Base help article called "How to create a Drop Ceiling" DJP Link to comment Share on other sites More sharing options...
Evolution Posted December 2, 2019 Share Posted December 2, 2019 Rob, with most commercial ceilings, the ACT mechanic will find the center of the room each way (assuming the layout as a square or rectangle), then layout so they have equal borders at the wall angle. Here where I build, if a border is 3" or less they will use a 4' tile and cut it to the over sized border (most architects / owners don' like those little slivers of tile at the walls). So, that is how I usually model a lay-in ceiling. I use the room poly-line for the wall molding, convert it to the wall molding in the library, and a polyline to set the centers , converted to a molding poly line using the "T" mold from the library, and work off them using the multi-copy both directions. This may not be what you are asking? Link to comment Share on other sites More sharing options...
winterdd Posted December 2, 2019 Author Share Posted December 2, 2019 Thanks guys. I watched the video on CA and it was explained well. However the offsets the narrator used doesn't perain to all designs. She never even explained how she got her offsets. Link to comment Share on other sites More sharing options...
Evolution Posted December 4, 2019 Share Posted December 4, 2019 On 12/2/2019 at 4:47 PM, ChiefUserBigRob said: Thanks guys. I watched the video on CA and it was explained well. However the offsets the narrator used doesn't perain to all designs. She never even explained how she got her offsets. Expand Rob, are you speaking of the border tiles for the perimeter border? If so, per my post above, this is the way I determine what the off-sets (border tile) are to be. If I knew how to make a video I would. I can usually do a room with average layout (other walls projecting in the room like closets etc) in just a few minutes. If you are using the library material Rectangle Ceiling Tiles with Lights, that will not give you what you want. Thus the reason I do lay-in ceilings as I do. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 4, 2019 Share Posted December 4, 2019 On 12/4/2019 at 7:28 PM, Evolution said: If you are using the library material Rectangle Ceiling Tiles with Lights, that will not give you what you want. Expand If you are ??? you can use the material definition Tool to move Material with the Offsets , same as you can on the Floor for Tile etc. The downside is that you will need a unique copy of the material for each room , so you can use different Offsets. M. Link to comment Share on other sites More sharing options...
winterdd Posted December 5, 2019 Author Share Posted December 5, 2019 On 12/4/2019 at 7:28 PM, Evolution said: Rob, are you speaking of the border tiles for the perimeter border? If so, per my post above, this is the way I determine what the off-sets (border tile) are to be. If I knew how to make a video I would. I can usually do a room with average layout (other walls projecting in the room like closets etc) in just a few minutes. If you are using the library material Rectangle Ceiling Tiles with Lights, that will not give you what you want. Thus the reason I do lay-in ceilings as I do. Expand Yes, i was speaking of the border. Thanks Link to comment Share on other sites More sharing options...
