GeneDavis
Why aren't framing members being counted for material list?
I have fully framed the job, and am testing to see what the material list produces for quantities.
All interior wall studs are either precut 9' or 8', thus 94 5/8" or 104 5/8".  It is not counting any interior wall studs or plates.  Yes, I have the walls turned on.
I'm set to mixed in structural reporting.  For 2x4 and 2x6, I have deleted all lengths except the precut 8 and 9 lengths and 16-footers.
I try a material list polyline to calculate just one wall.  No plates, no studs.
What's up with this?
Deleted all framing.
Using a standard interior-4 wall saved in the library and drawing 4 new walls, building framing for them and one of your walls, then generating a materials list, I see the framing for the new walls only.
Don't know why.
Problem is I edited every single wall detail.  Deleting it all loses all that work.
94 5/8"?
Our "8'" pre-cuts are 92 5/8" out west.
I tell new framers get used to feet and inches or FIS.
7'-8 5/8"
8'-8 5/8"
9'-8 5/8" and so on.
Not really sure if this may or may not be a factor as I have been having difficulties understanding the Manual recently and how it relates to functionality of the software.
Calculate Materials From Selection:
Select one or more objects and click the Calculate Materials From Selection edit button to create a Materials List that calculates only the selected objects and their components.
When the selected object is a room, its moldings and wall, floor, and ceiling finish materials are counted, as is its subflooring; but doors, windows, and structural materials like framing and other structural materials are not.
This may be a bug or just something I don't understand. :(
Actually I just gave the Materials List Polyline and the Calculate Materials in Area tools and they both seem to work.  So it must be something in Preferences that is different as I did not change any plan settings.
Gene,  Are you including your Wall Details in the documentation ?   I often do a Framing Schedule for each wall detail on a complicated build as it gives a positive verification of exactly where the material is being used.  Just another option if the Material List is not going to be effective.
Hi Gene,
                  You made a new Layer for Interior Walls and you have turned off the ML Reporting for your Walls,Normal Interior Layer , turn it back on in the ALDO and I think all will be well.
Mick.
image.thumb.png.c4e5da4008450f597e06b371fafe7e81.png image.thumb.png.5f083fce3c51b6b98c249cd804637142.png
  • Upvote 2
The Room ML only includes items inside the drywall line of the Room  , hence studs etc are not included.  ( furniture and finishes are AFAIK though)
    27344
    SilverAstronauts
    SilverAstronauts
