Joe_Carrick Posted September 13, 2019 Share Posted September 13, 2019 Here's my version of a Room Finish Schedule using a Note Schedule instead. All columns are filled in with custom macros. The macros are assigned to custom fields of the Note which labels the room in the plan. 1 1 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 13, 2019 Share Posted September 13, 2019 nice Joe. I noticed that you don't show the total square footages, probably a good thing as I can never get the room finish numbers to match the site info.. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 13, 2019 Author Share Posted September 13, 2019 25 minutes ago, DRAWZILLA said: nice Joe. I noticed that you don't show the total square footages, probably a good thing as I can never get the room finish numbers to match the site info.. It's always going to be a problem since there are chases and other areas that don't get included in the Room Finish Schedules. In addition, the site information is typically "Standard Area" while I'm just showing "Interior Area" in my Schedules. You might also note that I have some columns that you can't get with Chief's Room Schedules. 1 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 13, 2019 Share Posted September 13, 2019 One more question , Is there a provision or a way to show new vs. existing vs. remodeled area? Also are you selling this. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 13, 2019 Author Share Posted September 13, 2019 8 minutes ago, DRAWZILLA said: One more question , Is there a provision or a way to show new vs. existing vs. remodeled area? Also are you selling this. It would be easy to add a field/column for New / Existing. I'm not selling this just yet as I want to get it refined a bit more. Currently it's a good concept but I really need CA to fix a few attributes so that everything is reported correctly. Link to comment Share on other sites More sharing options...
MarkMc Posted September 13, 2019 Share Posted September 13, 2019 Looks good Joe. Guess you're waiting for show wall finish? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 13, 2019 Author Share Posted September 13, 2019 3 hours ago, MarkMc said: Looks good Joe. Guess you're waiting for show wall finish? That and correct dimensions for moldings. Currently the attributes are nominal vs exact and the width always shows as 1" The Wall Schedule takes care of the substrate material so for Wall Finish I could use "Wall Coverings" but that's limited to just 1 per Room. 1 Link to comment Share on other sites More sharing options...
Doug_N Posted September 14, 2019 Share Posted September 14, 2019 Joe, I am getting very excited about this! My only question is when? I have to do this on every darn project I do, the room area glass thing. The other thing is the unprotected wall openings in exterior walls that have a limiting distance. The code requires the designer to calculate the percentage of the sum of window opening area as a percentage of the wall above the grade and below the eaves. If the wall is less than 4' from the property line then no unprotected (window) openings are allowed. At 4' you may have about 7% unprotected opening, and that percentage goes up and the distance from the wall to the property line increases. In general, you make the calculation based on a percentage from a table in the codebook. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 14, 2019 Author Share Posted September 14, 2019 Hi Doug, I have the glass area thing already. I had messaged you about that weeks ago but hadn't heard anything from you. I figured you had decided you didn't need it. The exterior openings and wall/property line relationships are a bit more complicated. I will look to see if it can be done. 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 14, 2019 Author Share Posted September 14, 2019 OK, so here's my analysis on the unprotected openings in exterior walls. Walls would need a custom field for distance to property line - user entered in the OIP for each exterior wall. Windows & Doors would need a custom field to associate with the wall they are in - again, user entered in the OIPs. I would need the table for the percentages allowed to do the allowed calculation. Wall areas are already available in Ruby Attributes Door areas are already available in Ruby Attributes Window areas already are available in Ruby Attributes So, it can be done. The key is making sure the user input listed in #1 & #2 is all done correctly. 1 Link to comment Share on other sites More sharing options...
Doug_N Posted September 15, 2019 Share Posted September 15, 2019 Hi Joe, Gosh my apologies, I didn't see your message. Yes I am still interested! my email is info@measurite.ca Link to comment Share on other sites More sharing options...
Doug_N Posted September 15, 2019 Share Posted September 15, 2019 Doors are not considered unprotected openings unless they have a window in them. The unprotected opening rule is for radiation through glass I think. Link to comment Share on other sites More sharing options...
Chele555 Posted December 18, 2024 Share Posted December 18, 2024 On 9/13/2019 at 11:11 AM, Joe_Carrick said: Here's my version of a Room Finish Schedule using a Note Schedule instead. All columns are filled in with custom macros. The macros are assigned to custom fields of the Note which labels the room in the plan. Joe, do you have a macro shop? I like this finish schedule and your wall schedule. Link to comment Share on other sites More sharing options...
Chiefsandman Posted June 9, 2025 Share Posted June 9, 2025 Hello Joe, I know this is an old post but I wanted to see if you are selling the finish schedule? Thank you Link to comment Share on other sites More sharing options...
