Slope Wall to Create Railing
I need to slope the front only of this wall in the direction of the arrow.  I've seen videos online where it can be done, but in this instance I do not get a grab handle.  Could that be since it is defined as a railing wall?  If anyone has an idea of how to do this, please let me know.  I will be adding stair railing on top to match the photo (2nd attachment).  Thanks.
Lots of conversation about this. Searching and searching and reading should get you going.
Steve has a video, I think.
As Mark indicated, the wall is easy -- you will need to get creative to do the railing.
56 minutes ago, MarkMc said:
Check reference manual starting at page 758, railing follows stairs.
Thanks.  The wall is not so easy.  I need the bottom of the wall to continue at the same angle - not turn parallel to the floor at the tip.  Also, the "railing" wall on the second flight of stairs does nothing with "follow stairs" checked.  If I pull the wall back flush with the bottom riser, I am able to achieve the correct look, however, the wall is not supposed to be flush with the 1st riser.  Any ideas?
Welcome to the wacky world of Chief stairs.
Sometimes you need to do things manually. Select a wall in elevation and reshape it, add a solid (or molding) for a cap, and use a 2nd set of stairs, or a symbol made from stairs for the railing.
The auto function for this has been vastly improved in X11 over my earlier thread linked above. Here's one I did recently using pony wall and the Railing Follows Stairs setting:
1798155063_ScreenShot2019-09-10at11_37_44AM.thumb.png.298983712981a99a2ffcb9ecabce2f59.png
That's all auto-generated, no P-solids or anything added.
32 minutes ago, Kbird1 said:
Don't forget to check the KB  (KnowledgeBase) or FAQ for a lot of your Questions , it is a very handy reference with short Tutorials for common issues...
https://www.chiefarchitect.com/support/article/KB-03107/creating-a-stair-rake-wall.html
Thanks Mick.  I read that article twice.  It didn't help with the quirky tip on the edge of the wall.  I ended up pulling the wall back to get the proper slope.  Although, not like the as-built, it will have to do.
You've probably found one of those little quirks , and there are a few with Stairs , that they are slowly improving year by year.
It's one of those small things that needs to be reported though or they never get fixed unfortunately, so please send TS the Plan file for review.
PS  the KB Articles all have a PDF download too , under Tools on the right if you want to save a Copy locally.
  • Upvote 2
  Thanks Mick.  Will do...
    29613
    Pav-Arch
    Pav-Arch
