raltd9245 Posted August 20, 2019 Share Posted August 20, 2019 I'm looking for an ada grab bar symbol which includes the vertical bar Link to comment Share on other sites More sharing options...
Ridge_Runner Posted August 20, 2019 Share Posted August 20, 2019 3D warehouse has several. Watch the poly count though; some symbols look really good but CA takes a hit if you use too many. Link to comment Share on other sites More sharing options...
raltd9245 Posted August 20, 2019 Author Share Posted August 20, 2019 3D warehouse has shut off older versions like mine. Here is the file if anyone can open and save a a DWG it would be greatly appreciated. Thanks Grab+Bars-+ADA+Toilet.skp Link to comment Share on other sites More sharing options...
Ridge_Runner Posted August 21, 2019 Share Posted August 21, 2019 @raltd9245I placed the grab bars in an X11 file. Hope you can use it. raltd9245-ADA grab bars.plan Link to comment Share on other sites More sharing options...
raltd9245 Posted August 21, 2019 Author Share Posted August 21, 2019 Thanks much. I'm looking for a symbol with the vertical GB. Link to comment Share on other sites More sharing options...
ACADuser Posted August 21, 2019 Share Posted August 21, 2019 If you want CAD this link has some. http://www.cadnav.com/3d/Grab-bar.html Link to comment Share on other sites More sharing options...
ACADuser Posted August 21, 2019 Share Posted August 21, 2019 Here is another https://3dwarehouse.sketchup.com/search/?q=grab bars Were you looking for the 'L' shaped grab bar? Haven't seen that one in 3D yet. Spoke too soon. https://3dwarehouse.sketchup.com/search/?q=grab bar Link to comment Share on other sites More sharing options...
ACADuser Posted August 21, 2019 Share Posted August 21, 2019 I added stretch planed to the L shaped one. Grab Bar L shaped.calibz Link to comment Share on other sites More sharing options...
raltd9245 Posted August 21, 2019 Author Share Posted August 21, 2019 20 hours ago, Ridge_Runner said: @raltd9245I placed the grab bars in an X11 file. Hope you can use it. raltd9245-ADA grab bars.plan What I was looking for Thank you so much Link to comment Share on other sites More sharing options...
raltd9245 Posted August 21, 2019 Author Share Posted August 21, 2019 ACADuser. you are a prince. Thank you so Much Link to comment Share on other sites More sharing options...
DG1949 Posted August 25, 2019 Share Posted August 25, 2019 Grab bars, including vertical, are in the Core Catalog under "Hardware>Bathroom Hardware". Link to comment Share on other sites More sharing options...
Walt_Alaska Posted September 15, 2021 Share Posted September 15, 2021 Grab bars are not in my Core Catralog CA Archetic 2021under "Hardware>Bathroom Hardware". I down loaded a file suggested on this string but don''t know how to access it in the program? Appreciat your help as I'm new the software. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 15, 2021 Share Posted September 15, 2021 22 minutes ago, Walt_Alaska said: Grab bars are not in my Core Catralog CA Archetic 2021under "Hardware>Bathroom Hardware". I down loaded a file suggested on this string but don''t know how to access it in the program? Appreciat your help as I'm new the software. It sounds like you are using Home Designer Arch. 2021 not Chief Architect Premier , so it would be best to ask questions over on the HomeTalk Forums (Blue Theme) as the libraries are Different in the Home Designer Series of Products. https://hometalk.chiefarchitect.com/ Link to comment Share on other sites More sharing options...
Walt_Alaska Posted September 15, 2021 Share Posted September 15, 2021 Thanks. I'm new at this and got here following support links. Link to comment Share on other sites More sharing options...
ACADuser Posted September 15, 2021 Share Posted September 15, 2021 Maybe looking in 3dwarehouse.sketchup.com may help Link to comment Share on other sites More sharing options...
