Adam_Gibson Posted August 19, 2019 Share Posted August 19, 2019 I have no problem creating custom extrusions, but I'm wondering what the best method would be to create this shape casing for various height windows. I don't think I've run into this before. Any suggestions? Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 19, 2019 Share Posted August 19, 2019 8 minutes ago, Adam_Gibson said: I have no problem creating custom extrusions, but I'm wondering what the best method would be to create this shape casing for various height windows. I don't think I've run into this before. Any suggestions? You could create a symbol of the sill, casings lintel all together with a center stretch plane in the y- axis, personally I would show a detail of the casing as shown and leave elevations with a square casing with a note pointing to the detail. Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 19, 2019 Share Posted August 19, 2019 34 minutes ago, Adam_Gibson said: Any suggestions? See if this works for ya: stretch planes should work RABS CUSTOM CASING.calibz Link to comment Share on other sites More sharing options...
Kenoeightspot Posted August 19, 2019 Share Posted August 19, 2019 Casings are symbols Link to comment Share on other sites More sharing options...
Adam_Gibson Posted August 19, 2019 Author Share Posted August 19, 2019 Thanks all. What I was shooting for was if there's a way to simply make casing in that shape, avoiding applying symbols to the windows. Renee, I like your approach. I'll get the exact dimensions for casing and lintel and use your method. You all are so generous with your time! 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 19, 2019 Share Posted August 19, 2019 Actually try this instead, change the bounding box to be inside edge: RABS STRETCHABLE WINDOW TRIM.calibz 1 2 Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 19, 2019 Share Posted August 19, 2019 2 minutes ago, Adam_Gibson said: You all are so generous with your time! helps me get motivated to start the next project If you're going to make them yourself, you can change the bounding box to be the inside edge minus your reveal on your jamb thickness...that way you can p,ug in exact dimensions and snap to center in x/y on elevation Link to comment Share on other sites More sharing options...
MarkMc Posted August 19, 2019 Share Posted August 19, 2019 Symbol for shutters, casing set to 1/8 wide, millwork above casing symbol with Z offset equal to minus casing width. Will place with window and you only need to resize the width of millwork above casing. In this case I have it at window width plus 12" (manually though). Adam window.plan Link to comment Share on other sites More sharing options...
Adam_Gibson Posted August 19, 2019 Author Share Posted August 19, 2019 Geez. You guys are amazing. I'm lost on how you, Mark, did your thing. I get using shutters (great idea). Did you make the P solids into shutter symbols? Link to comment Share on other sites More sharing options...
MarkMc Posted August 19, 2019 Share Posted August 19, 2019 Yes psolid into shutter. Molding with psolid to symbol for Millwork above casing. Symbols on floor for reference to see origins and stretch planes. Parts used to make em also included. Did not try a macro to size width of millwork but doubt that can be done Link to comment Share on other sites More sharing options...
Adam_Gibson Posted August 19, 2019 Author Share Posted August 19, 2019 Any reason do not just create a custom lintel for the top millwork? Link to comment Share on other sites More sharing options...
MarkMc Posted August 19, 2019 Share Posted August 19, 2019 1 hour ago, Adam_Gibson said: Any reason do not just create a custom lintel for the top millwork? Guess since often when I've had to do odd windows that wouldn't work so I just default to treatment millwork above. I find it a bit easier to control since all I ever have to do is change origin and width, drag new symbol in place to see. I suppose in this case you could make a lintel work. A quickie using the molding I used for the symbol needs help though. Link to comment Share on other sites More sharing options...
MarkMc Posted August 19, 2019 Share Posted August 19, 2019 As in, took a look at what I did earlier (just before nap :) and didn't like protrusion. Changed origin, dragged onto window. Better, fast Link to comment Share on other sites More sharing options...
StephenGreene Posted August 19, 2019 Share Posted August 19, 2019 4 hours ago, Renerabbitt said: Actually try this instead, change the bounding box to be inside edge: RABS STRETCHABLE WINDOW TRIM.calibz I love the siding. Where did you find it? Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 20, 2019 Share Posted August 20, 2019 28 minutes ago, StephenGreene said: I love the siding. Where did you find it? Grabbed it off the net, made it tileable, made a bump/metal/roughness map...Think it's pretty high resolution. Try it out: RABS Weathered Fir Siding.calibz Link to comment Share on other sites More sharing options...
StephenGreene Posted August 20, 2019 Share Posted August 20, 2019 6 minutes ago, Renerabbitt said: Grabbed it off the net, made it tileable, made a bump/metal/roughness map...Think it's pretty high resolution. Try it out: RABS Weathered Fir Siding.calibz Somehow, I just knew it was something that you customized. Thank you!! Link to comment Share on other sites More sharing options...
Adam_Gibson Posted August 20, 2019 Author Share Posted August 20, 2019 Thanks again. I used both of your methods with good results. I really appreciate your time and generosity! The home was built around 1850 as a double. We plan to jack it up and dig a full basement. The historical society will want renderings, so this helped immensely. We can't change the facade at all, other than replacing siding and windows. 1 Link to comment Share on other sites More sharing options...
Ridge_Runner Posted August 20, 2019 Share Posted August 20, 2019 Looks good, Adam. Link to comment Share on other sites More sharing options...
