Door Shown As Glass In Elev But Not In Perspective
4hotshoez
And is not glass in the model. Why is it showing different?
I have never noticed that before.  Take a look straight on of the corner cabinet,  it now looks good,  but now the other cabinets are showing the shelves.
I tried in new  plan and same thing. I can't believe I have never seen this before.
If it is any consolation to you,  once you send to layout,  all is well.
It's z-fighting, at least that was what I was told back when. Change the angle of the perspective and it shows in different cabinets.
I have all my templates set with shallower depth shelves standard to avoid it. Have actually considered setting them up with none since I rarely put in a base with shelves and never have a need to show them, just apex qty.
.......... reduce the depths on the shelves if I don't want to see it in elevation. ......
That is the best solution,  just go into the cabinet defaults and reduce the default shelf depth by a 1/4" and all will be good.   But again,  it does not show in layout.
