INTERMEDIATE/ADVANCED PBR VIDEO
Renerabbitt
This video is pretty long, looking for a ton of feedback so I can narrow down a direction and compile videos that will be meaningful to everyone.
Going over some good tricks and tips for creating awesome looking scenes with little to no effort after templating
Your video on PBR shows the possibilities. However most of what you went over was too advanced for me. Needless to say...but i was amazed.
Also...I’m always torn about the value of spending a lot of time on rendering scenes.  Seems like I waste a lot of time trying to get things just right...but can’t be compensated for the effort required.
I would like you to do short videos that explain some of the basics...such as “what is an ambient occlusion map and how do you create one”.  Then, where do you store the maps you have created.  Same with the other maps.  How do you create...what they do...and where do you keep them on your computer.  Basic stuff...start at the beginning.
One more thing.  How do you post a video on Chief Talk without posting to YouTube?
Thanks for doing a great video.  Very eye opening.
Rene, nice video, it seems to explain it all. Lots to ponder. I do lots of mostly con doc's so never get into that much detail with my renders,  Scott and I call our renders "Crappy renders" mostly b/c we didn't want to wait for ray-traces.  Thanks for the lesson and tweaks to get them better.
Exactly what I was hoping for in a response, thank you very much.
I know I wasnt very clear in the video but one of the major points is that I only have to setup these default materials once and then all subsequent kitchens etc. Will look good with only a few minutes time. I ended up saving all the materials to defaults after the video.
I'll break a video into parts as suggested .
Do you have a kitchen .plan file you could share? I could use it as an example
Thanks as well.. do you happen to have a crappy render .plan to share ? Haha
21 minutes ago, johnny said:
Does anyone know if its possible to export Chief files WITH all the texture and reflection maps???  Using PBR would be incredibly useful if there was a way to export the work into a rendering app that continued the process.
Not that  know of- The material files I use in Thea use the same material diffuse/bump/normal/roughness maps as CA so that I don't need to constantly update both
Quoted you above so you would see this post;
I downloaded your "Starter Kitchen Material Package" from your "X11 Ongoing Symbols Thread"...but I'm getting a "texture missing" on a number of the materials. Is this correct?
I love the recessed light you created...works fantastic.  The subway tile is great also...
24347217_RABSKitStarter-TextureMissing.thumb.png.2a32ad7d2b8c47bf76875d8733308e6b.png
Can you list which materials are missing, or screenshot for me?
34 minutes ago, SNestor said:
5131 Calacatta-Ceasarstone
ALDER DEFAULT CABINET
Ceiling Gyp Bd
Oak Plank Floor
Wall Textured Gypsum Board
mind trying this out and see if you get the same problem:
RABS_STARTER_KITCHEN_MATERIAL_PACKAGE.calibz
5 minutes ago, SNestor said:
Same result...maybe someone else should try downloading.  Maybe I'm screwing something up.
No I think it has to do with CA backing up textures to the data folder...as soon as I point to the texture in my file structure it redirects to CAs data folder
When exporting CA all the textures come with the model.
I use Thea and apart from the glass which need changing, Only all of the diffuse and roughness maps get exported.
I suppose i have to find in setting how to allow the other maps to be exported.
try this :    Use the Library Import Button , don't Drag and Drop   I have seen this on some of my shared Libraries too.
Imported just fine for me from the Symbols Forum.  10 items correct?
Package Imports into X10 as well ...but won't open there , I did it 1st there by accident :)
Mick
