MN_JohnH Posted January 17, 2019 Share Posted January 17, 2019 I am wondering if there is a simple way of aligning the custom tile in a custom backplash? In the attached drawing I have created two custom tiles for this hypothetical shower. The big tile is 24x24 and I would like to have it go 5' up on the wall and then have a 12" deco strip of 2x2 tile and then more of the larger tile above that to the ceiling. Problem is I want a full tile on the top of the 5' high lower part, (the half cut would be on the bottom), and then start with a full tile on top of the deco strip. And my deco strip is 2x2 tile, I made it as a 12x12 square of 2x2 tile and yet it doesn't line up as full tile on the top and bottom edges... Tile alignment.plan Link to comment Share on other sites More sharing options...
rlackore Posted January 17, 2019 Share Posted January 17, 2019 We don't have access to your textures unless you export using Backup Entire Plan. That said, you may be able to achieve your desired result this way: Link to comment Share on other sites More sharing options...
MN_JohnH Posted January 17, 2019 Author Share Posted January 17, 2019 Thanks. Here is everything in the folder with the entire backed up plan. I figured it has something to do with the offset and angle as you are pointing out but there seems to be no rhyme or reason as to where those offsets are based. If they are both set at zero then i would think my 2x2 tiles would line up full at the top and bottom. And if this is the only way to adjust it then I would have to create new materials for every layout application. Seems like there would be an easier way. Thanks, Tile alignment.plan Link to comment Share on other sites More sharing options...
rlackore Posted January 17, 2019 Share Posted January 17, 2019 Next time please Backup Entire Plan and save as a zip: You can achieve your goal very easily: 1. Create a copy of your 24x24 material and assign it to the top backsplash, then adjust the X/Y values as needed: 2. Adjust the deco strip using the Y Position offset: You get: 1 Link to comment Share on other sites More sharing options...
MN_JohnH Posted January 17, 2019 Author Share Posted January 17, 2019 Thanks. So I guess the answer is yes I do need to create a different material for each layout application and then tweak the values till they come out right. I guess it's not as hard as I thought to do all that. It's still puzzling that my first try was using 24x24 tile and I had an area 5' high and the values set at 0 or 12, I would think it would come out and a full tile on top or bottom and a half cut on the opposite I had to change the value to 13 to get it to eliminate that 1" cut at the top. Anyway, thanks for the help! Link to comment Share on other sites More sharing options...
Renerabbitt Posted January 17, 2019 Share Posted January 17, 2019 On 1/17/2019 at 3:24 PM, MN_JohnH said: Thanks. So I guess the answer is yes I do need to create a different material for each layout application and then tweak the values till they come out right. I guess it's not as hard as I thought to do all that. It's still puzzling that my first try was using 24x24 tile and I had an area 5' high and the values set at 0 or 12, I would think it would come out and a full tile on top or bottom and a half cut on the opposite I had to change the value to 13 to get it to eliminate that 1" cut at the top. Anyway, thanks for the help! Expand You may find it faster to use material regions and the multiple copy tool to make individual tile, this can be made to look very realistic as well...did this back in 2013 using that method: 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted January 17, 2019 Share Posted January 17, 2019 On 1/17/2019 at 3:24 PM, MN_JohnH said: Thanks. So I guess the answer is yes I do need to create a different material for each layout application and then tweak the values till they come out right. I guess it's not as hard as I thought to do all that. It's still puzzling that my first try was using 24x24 tile and I had an area 5' high and the values set at 0 or 12, I would think it would come out and a full tile on top or bottom and a half cut on the opposite I had to change the value to 13 to get it to eliminate that 1" cut at the top. Anyway, thanks for the help! Expand The Layout of the Tile is done in Respect to the 0,0 point on the Coordinate grid, not from where-ever you place the tile, that is why you need different materials.....( same material-renamed) so you can set different Origins (otherwise they would all follow the change). I usually use Wall Material Regions these days for do this sort of thing. I think you can delete all the textures you posted above to cleanup the thread.... M. 1 Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted January 17, 2019 Share Posted January 17, 2019 This may help, it's my way of visualizing how textures work. When you apply a texture it's not actually contained with the boundaries of the surface you applied it to. The texture is applied like a layer to the entire plan and the boundary of the surface you applied it to is like a window that allows you to see that specific portion of the texture layer. As Mick mentions the texture layer is based on the 0,0 origin, when you change the texture x,y offsets it shifts the texture on it's layer relative to the 0,0 origin, it is not shifting the texture according to the boundaries of the applied surface, it just looks as if it is. As such, if you use the same texture on another surface then it's window is just allowing you to see the same texture layer but at a different location within that texture layer. This is why if one wishes the texture to have a different position on two different surfaces then you must make a copy to create a separate texture layer and then apply this to the other surface and manipulate it. 1 Link to comment Share on other sites More sharing options...
MN_JohnH Posted January 18, 2019 Author Share Posted January 18, 2019 Thanks everyone. Very helpful. Link to comment Share on other sites More sharing options...
