rockyshepheard Posted January 11, 2019 Share Posted January 11, 2019 Is there an easy way to add a given amt of height to all ceilings on a single floor at once (as measured from the finished floor)? Link to comment Share on other sites More sharing options...
tommy1 Posted January 11, 2019 Share Posted January 11, 2019 Try setting your floor default. 1 Link to comment Share on other sites More sharing options...
Richard_Morrison Posted January 11, 2019 Share Posted January 11, 2019 And if that doesn't work because some rooms don't have a default ceiling height, there is the "Match Properties" tool. 1 Link to comment Share on other sites More sharing options...
lbuttery Posted January 11, 2019 Share Posted January 11, 2019 Rockney: I think you mean to an all ready modeled plan say with 8' ceilings to change to 9' ceilings automatically I know in the "old" days there wasn't a really good way to do this but I "retired" in 2012 and have lost track on this issue so "match properties" may do the trick - but probably need auto-roof rebuild and auto-framing rebuild etc turned on I remember having to doing a few of these adjustments back around 2008 and there was some cleanup work that needed to be done afterwards today ... maybe not ? Lew 1 Link to comment Share on other sites More sharing options...
SNestor Posted January 11, 2019 Share Posted January 11, 2019 1 hour ago, rockyshepheard said: Is there an easy way to add a given amt of height to all ceilings on a single floor at once (as measured from the finished floor)? "EASY" is a relative term. If you know how to do these things...yes, then it's fairly simple. If you don't...well, frustration station is just ahead. If you are referring to the plan you posted recently...well, the entire plan is one big room. You can open "defaults" and go to floors/rooms tab and change the default height. The plan ceiling height will change. However, if you have a roof on this plan...the roof will not move. You will have to manually move the roof planes up or down in the "Z" axis the same dimension you raised or lowered the default ceiling height. (did we lose you?) 1 Link to comment Share on other sites More sharing options...
rockyshepheard Posted January 11, 2019 Author Share Posted January 11, 2019 Thanks all! Link to comment Share on other sites More sharing options...
