dskogg Posted December 23, 2018 Share Posted December 23, 2018 Hi all, i have this basement plan and when i go to full extents it zooms way out...I cant find out where the rogue object is. I have attached plan for anyone to open and try and let me know what is going on. Any help would be appreciated. smith basement.zip Link to comment Share on other sites More sharing options...
dskogg Posted December 23, 2018 Author Share Posted December 23, 2018 eric if i delete current floor command, wont that delete the plan? this design is for a basement. Link to comment Share on other sites More sharing options...
dskogg Posted December 23, 2018 Author Share Posted December 23, 2018 i will try it, i copied and pasted plan into a new one and that seemed to work. Merry Christmas Link to comment Share on other sites More sharing options...
Kbird1 Posted December 23, 2018 Share Posted December 23, 2018 It looks like you may have a PDF in the Plan?, ( one layerset is complaining it can't find RED.PDF for the view) that I guess isn't saved in the Plan I have, as even All On does not display it .......and perhaps the overview cameras are centering on it's location?..... Link to comment Share on other sites More sharing options...
Chopsaw Posted December 23, 2018 Share Posted December 23, 2018 It is definitely something that is or was on the CAD, Default Layer but it seems to be not visible. Link to comment Share on other sites More sharing options...
glennw Posted December 23, 2018 Share Posted December 23, 2018 I believe the problem is caused by an errant polysolid being used for a door. It is located on the left hand side of the 4064 door that leads into Kaylah's Kraft Korner. Delete the polysolid and the zoom works as expected. Also...when I try and use Edit Area, I keep getting font replacement error messages - not quite sure what is happening there as the error dbx keeps opening. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 23, 2018 Share Posted December 23, 2018 Nice find G. how did you notice that? the RH door is an Arch.Block and the LH one isn't for some reason, deleting it and copying the RH one over to the left also fixes the zoom issue.... though we have premade Barn Doors in the Bonus Door No.1 library... (there are 4 bonus door libs. btw) https://www.chiefarchitect.com/3d-library/index.php?r=site/detail/895 Link to comment Share on other sites More sharing options...
glennw Posted December 23, 2018 Share Posted December 23, 2018 13 minutes ago, Kbird1 said: Nice find G. how did you notice that? I deleted groups of objects and tried the zooms after each deletion. It then doesn't take too long to figure out what is causing the problem. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 23, 2018 Share Posted December 23, 2018 2 minutes ago, glennw said: I deleted groups of objects and tried the zooms after each deletion. It then doesn't take too long to figure out what is causing the problem. Thanks ! good trick to remember..... M. Link to comment Share on other sites More sharing options...
dskogg Posted December 23, 2018 Author Share Posted December 23, 2018 Thanks do much everyone.. it never ceases to amaze me the help I get on this forum, thank you. ca says I can just go to library and drop a door wherever I want.. but the only go into walls. the reason I wasn’t using the bonus library for barn doors is I lock the rolling brackets to door and then I can open or close barn door by selecting and sliding left or right, this can not be done with preloaded doors. i also just stretch track to suitable length based on opening. anyone have tips and tricks they use with barn doors? Link to comment Share on other sites More sharing options...
Chopsaw Posted December 23, 2018 Share Posted December 23, 2018 6 minutes ago, dskogg said: anyone have tips and tricks they use with barn doors? Yes I have resorted to similar methods but then create new symbols for the edited or recreated doors and track. As a symbol you can use the "Reverse Symbol" option to open and close or just select and move independent of the track like it appears you do. Link to comment Share on other sites More sharing options...
dskogg Posted December 23, 2018 Author Share Posted December 23, 2018 Thanks.. I think I was saving as a block to my library.. not sure why, I have created and saved many symbols to my library... then you can stretch and reverse.. cheers Merry Christmas Link to comment Share on other sites More sharing options...
