srjbb97 Posted September 26, 2018 Share Posted September 26, 2018 Hello, I believe I have had help previously on this issue, but I have tried what I previously tried to try and fix this issue. Can anyone help? Thank you, Shonna Link to comment Share on other sites More sharing options...
srjbb97 Posted September 26, 2018 Author Share Posted September 26, 2018 3 minutes ago, solver said: Maybe -- If you post the plan file. It isn't perfect yet, but we are trying to get it well enough to have a 3D view Lot 125 3car.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 26, 2018 Share Posted September 26, 2018 DJP Link to comment Share on other sites More sharing options...
dshall Posted September 26, 2018 Share Posted September 26, 2018 It has to do with your wall definition layers Link to comment Share on other sites More sharing options...
srjbb97 Posted September 26, 2018 Author Share Posted September 26, 2018 Thank you all for the help!! Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 26, 2018 Share Posted September 26, 2018 Every time you drag walls down the whole wall follows so your bottom plate will be at the bottom of the floor joists level. I never try to drag walls, it will mess up your sections. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 26, 2018 Share Posted September 26, 2018 3 hours ago, solver said: As Scott said -- review you wall settings. The Siding is set at 0" thick (see Scott's Pic).....should likely be 3/4" ? that fixed it for me..... However the Siding 11_2 in my plan has all the above in red set to OSB already M. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 26, 2018 Share Posted September 26, 2018 YOU MIGHT ALSO CHECK THIS Link to comment Share on other sites More sharing options...
