Designer100 Posted September 6, 2018 Share Posted September 6, 2018 When I am moving a wall it shows decimals instead of regular temp dimensions. Any suggestions on how to get this back normal. When I draw dimensions, they area correct. Thanks for any help. Chief x10, Windows 10 newell.cheatheam@gmail.com Link to comment Share on other sites More sharing options...
Chopsaw Posted September 6, 2018 Share Posted September 6, 2018 They should be the same. Are you sure that you are not just dimensioning items that have no decimals. A plan file or screen shot would be helpful. Link to comment Share on other sites More sharing options...
AvoyeDesign Posted September 6, 2018 Share Posted September 6, 2018 Is this what you mean? I've always seen this in decimal inches, not sure if there is a control for that. Link to comment Share on other sites More sharing options...
glennw Posted September 6, 2018 Share Posted September 6, 2018 Doesn't that depend on the current dimension style default? Link to comment Share on other sites More sharing options...
Kbird1 Posted September 6, 2018 Share Posted September 6, 2018 It's a bit strange as in a current test drawing with decks on 3 sides of the house I have it displaying 3 different ways --- for 3 different measurements 10' 2 3/4" shows as 10' 2" 18/25th" 12' 1/16th shows as 12' 0.0525" (and 9' 1" 1/16th shows as 9' 1.3025") The house interior is 25' 9" and shows as 25' 9" so it might depend on how accurate the drawing is perhaps ? I didn't find a setting to get them all the same however. My 1/4" defaults are set for 1/16 accuracy currently Link to comment Share on other sites More sharing options...
