Member Statistics
Similar Content
By Sunnyfields
I am trying to do a presentation plan and am using a top down orthographic view with watercolor and overlaid lines. I can't get the resolution I need exporting an image from CA so I have sent the view to Layout as a live view. We also tried it as an image. The problem is that every time I try to create a PDF two walls disappear. The view box is large enough, so I haven't cropped the view, I've had our veteran Chief guy look at it, and we're stumped. Here is the result:
Here is the view in Layout:
And Here is the print preview:
Has this happened to anyone else? I have tried outputting this about a dozen times and the same two walls are cut off every time.
I am running CA Premier X12 on a Dell with these bells and whistles. I also have Bluebeam Revu as my PDF print driver in addition to the "Export" function in CA. I have tried to print and to export with the same result . Any help would be appreciated.
By divreig
I have imported the loading doc roof I did in sketch up the, the structure is 3852" wide . Chief imports the correct size, but then when i try to move it up to the correct height chief shrinks the imported roof structure to 3000". I did not find any limits on imports on the docs or help.
Anyone ells had this problem?
existing model.plan
existing roof only.skp
By divreig
I imported a Import a surveyor DWG file. I followed the instruction in the tutorial (Import a Surveyor DWG file for a Site Plan or Terrain Perimeter (chiefarchitect.com) . And got some strange spikes hills. I have tired cleaning up the elevation data but no luck. There is simply no elevation data in the area that is that tall, not sure what is generate this. Pleas see the attached pic and surveyor map.
17045-Topo.pdf
17045-Topo-C.dwg
existing terrian2.plan
By rfantclt
Fellow More-experienced CA users,
I have drawn as-built plans of a house for a renovation/addition project in CA v.12. I recently received the final survey from the surveyor with property lines, major and minor contours, the building footprint, and other typical survey information. I imported it from .dwg as a .plan file with layers for terrain perimeter and terrain, and converted the terrain using the convert tool to make it 3D. It shows up with terrain. Yay! Now I'm not sure of the next steps:
1. How do I bring the terrain into the building.plan?
2. How do I set it in place - using a Place Point or Point Marker at a corner of the house?
3. The survey elevations are in the 650' range so how what do I do to place the terrain relative to my house (1st floor 0.0)? This house has a walk out basement, if that matters.
4. I copied in a 2D version of the survey to use in plan view (on layer CAD, AS-BUILT SURVEY). When I send it to layout, the house floor plans are obscured and the secondary contours didn't come in - admittedly, this is a previous version of my survey attempt and I've since remapped the survey layers.
I have also attached the house plan, if that helps.
Thanks for recommendations from this group, as I've watched numerous videos and couldn't find any that addressed this process.
Rebecca
CA Premier X12
Zoutewelle FINAL SURVEY.plan
Muhs Existing.plan
