Not working; Importing Sketch-up into Chief
Ange822
Hi there,
I am new to this ChiefTalk / Forum but i need help.
I am trying to Import a 3D Sketch-up object from the 3D warehouse into chief. It is a Teknion office product.
When i go to File - Import - Import 3D symbol - attach the document, i get the attached pop - up.
Any idea's what the issue could be?
I am using X9.
thanks,
Angela
I found the issue. I had to click on the object in the 3D warehouse and download it as an older version of sketchup.
Now it's importing correctly.
My next question; how do i change Materials if the object comes in as one colour/material.
thanks,
Angela
32 minutes ago, Joe_Carrick said:
You can't.  The Sketchup object has to have separate materials.
Could perhaps Open it in SketchUp and change the Materials there after Exploding it and re-save it and re-import into Chief....
Some-one with more SU Skills will have to advise further if you need to do that
I remember another thread on Teknion and their symbols all being White Or Orange but only one Color but don't think I saw a solution posted...
It is do-able in SU2107 , select the Object , RC>Explode and then use the Menu/TAB on the Right to play with Materials using the Paint Bucket Tool , then save and import into CA. It will then come into Chief with separate Materials which you can then Change to any Material in Chief......
I think Teknion was probably Lazy converting the Files , ie they imported the .DWG into SU and just immediately saved in SU to .skp hence the one Material.
This is the Original Teknion Zones Chair and the one I "played" with....
