QualicoreHomes Posted August 7, 2018 Share Posted August 7, 2018 Hello, I started a drawing of a shop that will have a mezzanine. After looking on this chat it seems that the only way to do that is build another floor and label the non mezzanine areas as open to below. I did this but now there is a line in the elevation drawing at the height were the "imaginary" floor of the second level is. Is there a way to get rid of this line? and also is there a simpler way to build a mezzanine? Appreciate your help! Mezzanine.plan Link to comment Share on other sites More sharing options...
glennw Posted August 7, 2018 Share Posted August 7, 2018 Have a play with a room designated as "Shelf Ceiling" - a room with a lower ceiling than the room that contains it - a mezzanine. Link to comment Share on other sites More sharing options...
ShaneK Posted August 8, 2018 Share Posted August 8, 2018 I use a landing for my mezzanine in most projects. Easy quick and it behaves, lol. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 8, 2018 Share Posted August 8, 2018 4 hours ago, QualicoreHomes said: Hello, I started a drawing of a shop that will have a mezzanine. After looking on this chat it seems that the only way to do that is build another floor and label the non mezzanine areas as open to below. I did this but now there is a line in the elevation drawing at the height were the "imaginary" floor of the second level is. Is there a way to get rid of this line? and also is there a simpler way to build a mezzanine? Appreciate your help! Mezzanine.plan You need to label the walls "Balloon thru ceiling above" and rebuild the wall framing is all.... Link to comment Share on other sites More sharing options...
QualicoreHomes Posted August 8, 2018 Author Share Posted August 8, 2018 Thank you much for the replies!! I used the landing tip in this plan but I think all 3 of the tips I will use in the future. This chieftalk to me is very valuable in learning the program, thanks to all the chiefs for their patience and knowledge!! Link to comment Share on other sites More sharing options...
