IvanCyr Posted July 4, 2018 Share Posted July 4, 2018 Hi all, I was wondering if anyone knows the answer to removing the second call out on the cabinet schedule. These seem to work in pairs. If you look at the attached pic, there are two red circled cabinets; I would like the callout in the diamond box to be hidden on this view (for example, the right cabinet has a sink in it)...but both callouts seem to come and go at the same time. Likely a single click somewhere to fix this...I just don't know where to click! Much appreciated. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted July 4, 2018 Share Posted July 4, 2018 The Diamond Box appears to be an Appliance Schedule Callout. Turn off the "Fixtures, Labels" Layer to prevent it from being seen. Link to comment Share on other sites More sharing options...
Chopsaw Posted July 4, 2018 Share Posted July 4, 2018 Hello Ivan, It would appear that you have a Fixture Schedule active as well as your Cabinet Schedule. How is it that they both come and go at the same time ? Link to comment Share on other sites More sharing options...
IvanCyr Posted July 5, 2018 Author Share Posted July 5, 2018 On 2018-07-03 at 10:50 PM, Joe_Carrick said: The Diamond Box appears to be an Appliance Schedule Callout. Turn off the "Fixtures, Labels" Layer to prevent it from being seen. The "Fixtures, Labels" is turned off. When I turn off the "Cabinets, Labels" all callouts disappear. All the labels on the page seem to be located on the "Cabinets, Labels" layer. Hope this is clear. Any suggestions? Ivan Link to comment Share on other sites More sharing options...
IvanCyr Posted July 5, 2018 Author Share Posted July 5, 2018 ...and just a further note of the sink. It is listed as an imported symbol. Opening up the symbol and looking at the "Symbol Specification" it shows: 1. Inserts into Contertop; 2. Under Schedules, "Treat as Plumbing in Fixture Schedule"; 3. Type: Sinks(Kitchen). Link to comment Share on other sites More sharing options...
Joe_Carrick Posted July 5, 2018 Share Posted July 5, 2018 12 minutes ago, IvanCyr said: The "Fixtures, Labels" is turned off. When I turn off the "Cabinets, Labels" all callouts disappear. All the labels on the page seem to be located on the "Cabinets, Labels" layer. Hope this is clear. Any suggestions? Ivan Not without the Plan. Link to comment Share on other sites More sharing options...
IvanCyr Posted July 5, 2018 Author Share Posted July 5, 2018 (edited) I really appreciate you guys looking at it. I've attached a screen shot showcasing the sink in question. Perhaps this helps. Ivan Edited July 5, 2018 by IvanCyr Proper Attachment Link to comment Share on other sites More sharing options...
Chopsaw Posted July 5, 2018 Share Posted July 5, 2018 Ivan, I don't think there is any way to have two different Callout shapes for one Schedule. You must have a Fixture schedule somewhere. Find it and open it to the Label tab and deselect "Show Labels". If it is any more complicated than that post the file for Joe. Link to comment Share on other sites More sharing options...
IvanCyr Posted July 5, 2018 Author Share Posted July 5, 2018 Thanks Joe...here' s the plan. Chopsaw, thanks for the reply. I opened up ALL schedules to review and didn't find those "Labels" in question as any items in any of the schedules. Likely a 2 bit easy click...but I've missed it. ChiefExample_e.plan Link to comment Share on other sites More sharing options...
MarkMc Posted July 5, 2018 Share Posted July 5, 2018 Delete the current sink, place a new sink away from the cabinet, click ok when it complains, drag it into position. It will show correctly in plan and 3d but will not show the callout as part of the cabinet. Delete the rangetop, alter the cabinet as it would actually be built without the appliance, float in the range top. You will have to alter the origin of the rangetop symbol OR change it's height, then position over the cabinet 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 5, 2018 Share Posted July 5, 2018 I concur with Mark. Place all those appliances and fixtures manually (disconnected from the cabinets). It's more accurate, more flexible, and more manageable. Link to comment Share on other sites More sharing options...
IvanCyr Posted July 5, 2018 Author Share Posted July 5, 2018 Thank you gentlemen, much appreciated. A fair bit more than a two click solution!!! LOL Np though...perhaps Chief can work toward segregating those items in X-11. Link to comment Share on other sites More sharing options...
MarkMc Posted July 5, 2018 Share Posted July 5, 2018 1 hour ago, IvanCyr said: .perhaps Chief can work toward segregating those items in X-11. Perhaps, been that way a long time now. It would be nice if it changed but I use the method described as SOP so no biggie; I'd rather see work on stairs, or... Link to comment Share on other sites More sharing options...
