imagekit Posted August 19, 2014 Share Posted August 19, 2014 when i select material as" mirror" i dont get a mirror finish , i just get a purple colour. how can this be fixed? Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 19, 2014 Share Posted August 19, 2014 That is what the "mirror" material looks like in a vector view camera view (no reflections except using a ray trace or standard render camera view). DJP Link to comment Share on other sites More sharing options...
imagekit Posted August 20, 2014 Author Share Posted August 20, 2014 i thought that the view that comes up where you can see the tile patern was the render view? i have just done a raytrace and yes the mirrors do show up,so how do i do a render veiw? and how do you get the mirrors to show up in a walkthrough ? which i have made and they dont show up. thanks Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 20, 2014 Share Posted August 20, 2014 I have no way of knowing what you did-did not do or with what. I do know that once you learn how to use the software by way of study and practice with the Reference Manual and provided you have a decent computer for it to run on, you or anyone else can get stunningly good results. It takes lots of concentrated study and then using what you learned during study to then be able to display competence to yourself and others. It is worth doing. Everything you need to know is resident in your Reference Manual and Help files. DJP 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 20, 2014 Share Posted August 20, 2014 Check these settings... 1 Link to comment Share on other sites More sharing options...
Solution Kbird1 Posted August 20, 2014 Solution Share Posted August 20, 2014 if you have toggled the Patterns off you won't see the tiles/grout lines in Vector View , if toggled on you should..... but still no reflections , they only show in Standard View and Ray Trace assuming you have the settings in the previous post. M. 1 Link to comment Share on other sites More sharing options...
imagekit Posted August 21, 2014 Author Share Posted August 21, 2014 thankyou , alaskan son and kbird1, as far as davidjpotter goes ,i thought this forums are for help not just(you no what its not worth it) Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 21, 2014 Share Posted August 21, 2014 You also won't see the mirror effect if you have an old mirror material in your lib. This was new in X6 so make sure you use that one. Link to comment Share on other sites More sharing options...
