Wall - "tabbing"
johnny
Funny, I thought that the tab entry method was acting up!!  I have always made a habit of double checking the angle when I hit tab to move things though, and so I never fully realized what was going on.  You are absolutely correct though Johnny, there is a problem in X10.  It works fine in some circumstances, such as when drawing a brand new wall/line (not using the diamond shaped edit handle) or while in continuous draw mode, but it does not work in many other circumstances (most notably when dragging off a new wall/line section when using the diamond edit handle or when moving the corner of a polyline based object)...
Thanks for pointing this out.  I have reported it.
The tab is acting up when I grab a side of a poly line,  I start to resize by dragging a side,  hit the tab key,  the dimension dialog box opens and then the number I may put in does not work.
