mealexmail Posted August 11, 2014 Share Posted August 11, 2014 Hi guys! I'm stucking with nothing again, yep =) The problem: how could I do corner cabinet with different widht from left and right side of it? For example, I need to do 500mm the left and 600 the right (see the pic attached) many thanks!@) Link to comment Share on other sites More sharing options...
rlackore Posted August 11, 2014 Share Posted August 11, 2014 See attached picture. Link to comment Share on other sites More sharing options...
mealexmail Posted August 11, 2014 Author Share Posted August 11, 2014 Yes, i tried this way, thank you. But may be is there way to do that using proper type of cabinet. Its important from specification and bill of materials point of view. And what is possibly even more important for correct elevation views. So the ball is still in game: is it possible? Link to comment Share on other sites More sharing options...
rlackore Posted August 12, 2014 Share Posted August 12, 2014 What exactly are you expecting in elevation view? Here's the same concept as I posted earlier, but with a corner cabinet as the filler, which will correct any problems with the toe kick. I'm no cabinet maker, but the BOM should be pretty darn close. Link to comment Share on other sites More sharing options...
mealexmail Posted August 13, 2014 Author Share Posted August 13, 2014 Uff .. I tried using filler but it gives no effect in perspective or elevation (cross section) views see pics attached kindly Link to comment Share on other sites More sharing options...
rlackore Posted August 13, 2014 Share Posted August 13, 2014 Post the plan. Link to comment Share on other sites More sharing options...
mealexmail Posted August 17, 2014 Author Share Posted August 17, 2014 Thank you keep helping me .. sorry, was out of internet coverage. So the plan is attached with dimensions that must be as pointed. Hope it'll make the issue clear ) And please proposing filler check that it displayed correctly in perspective view and elevations UPD its not allowed here to upload *.plan file .. (( so i can upload jpg (( if you encounter same issue please feel free to send attachments to my email directly (me.alexmail@gmail.com) Link to comment Share on other sites More sharing options...
lbuttery Posted August 17, 2014 Share Posted August 17, 2014 close the plan then zip it before attaching to a post to zip right click the file select send to give the file a name and save to your hard drive Lew Link to comment Share on other sites More sharing options...
Electromen Posted August 17, 2014 Share Posted August 17, 2014 What if you make your filler cabinet look like #4.jpg and make it full depth? Link to comment Share on other sites More sharing options...
mealexmail Posted August 18, 2014 Author Share Posted August 18, 2014 I've put plan into zip file Please check attached Dimensions I pointed there are the must. So i need to fill the corner correctly thank you corner_closet.zipFetching info... Link to comment Share on other sites More sharing options...
Solution Electromen Posted August 18, 2014 Solution Share Posted August 18, 2014 Don't use a corner cabinet, use an angled cabinet. Decide if you want one long cabinet to the right or two cabinets as I've shown in my previous post #9 Using two cabinets will allow you to adjust the toe space Revised plan attached corner_closet.plan.zipFetching info... Link to comment Share on other sites More sharing options...
mealexmail Posted August 18, 2014 Author Share Posted August 18, 2014 Thank you, I'd rather use two cabinets here to change shelves, remove doors etc. I think, this solution is ok for me And yes I shouldnt use corner cabinet. Can't explain why I did that =)) thank you very much again Link to comment Share on other sites More sharing options...
MarkMc Posted August 19, 2014 Share Posted August 19, 2014 Be a good idea to check clearances-remember Chief doesn't show doors in plan. With 1mm reveal the doors will overlap each other, need much more to open- a typical angled corner molding won't be enough.. Link to comment Share on other sites More sharing options...
mealexmail Posted August 19, 2014 Author Share Posted August 19, 2014 Yes, quite good idea! thanks, Mark Link to comment Share on other sites More sharing options...
