Designer100 Posted April 17, 2018 Share Posted April 17, 2018 is there a way to flip a pdf floor plan in chief Architect x10. I am doing a remodling plan and I have old set of plans, but it is a reverse of what was built. I was going to scan it to pdf or jpeg and use to trace over for remodeling. Is there a way to flip a pdf or reverse it in chief or do I need to draw over existing then flip in chief? Newell Cheatheam Chief x10 windows 10 Link to comment Share on other sites More sharing options...
Chopsaw Posted April 17, 2018 Share Posted April 17, 2018 I think I can do that for you if you would like to post the pdf or send it to me. It will mess up the text though. Also I can convert to .png that will import better if you like. Not the drawings, just the pdf conversion. Link to comment Share on other sites More sharing options...
Chopsaw Posted April 17, 2018 Share Posted April 17, 2018 Actually Newell, I think you just discovered a new X10 Bug. PDF's can be reflected vertically but not horizontally and even if you rotate the PDF before importing it just seems to assume that you would never want to destroy the text or something. Somehow it knows even if you try to trick it. But why ? If you don't like it you could just hit undo or reflect back the other way. Please send this in to tech support and let us know how it goes. In the mean time you can use Chief to import the PDF and then export to PNG and re-import again so you can reflect it as an image. There always seems to be a way. Just not always an easy one. Link to comment Share on other sites More sharing options...
RL-inc Posted April 17, 2018 Share Posted April 17, 2018 Might be easier to trace in current view and then edit area to reverse. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted April 17, 2018 Share Posted April 17, 2018 2 hours ago, RL-inc said: Might be easier to trace in current view and then edit area to reverse. Or use Tools>Reverse Plan Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 17, 2018 Share Posted April 17, 2018 I will just draw the walls in the reversed state first, then use transform replicate to flip it vertically Link to comment Share on other sites More sharing options...
JJohnson Posted April 17, 2018 Share Posted April 17, 2018 pdf files seem to really slow CA down on my set up, so I scan to jpg then import. If you can get the file scanned to jpg, you can reverse in in Paint Shop, jpg files just work better in CA in my opinion. 1 Link to comment Share on other sites More sharing options...
