CCCArchitect Posted August 7, 2014 Share Posted August 7, 2014 Came into work this morning and somehow my mouse wont orbit my model. Directional side to side and up and down only......help X6 Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted August 7, 2014 Share Posted August 7, 2014 My first thought is to close CA and then reopen it. Sometimes that's all it takes when CA is doing something really weird. If that doesn't work and you don't get a better response from someone else contact tech support. Link to comment Share on other sites More sharing options...
CCCArchitect Posted August 7, 2014 Author Share Posted August 7, 2014 Thanks....I zoomed out and it appears I my rotation point has somehow changed, the model rotates around some unknown point? is there a way to change how the mouse controls the rotation?? Link to comment Share on other sites More sharing options...
KilgoreTrout Posted August 7, 2014 Share Posted August 7, 2014 Assuming that you are using one of the overview cameras, then your camera will orbit around the center of the model. If there is something in your model that is way out in timbuktu, then your center will not be where you want it to be. Find it and fix it and your camera tools will work right. Also, you can always just use the full camera tool and the center of orbit is set by the camera focal point (where you stop drawing the camera). Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 7, 2014 Share Posted August 7, 2014 In Plan View, you can grab the Focal Point of the Camera and move it wherever is convenient. I a perspective view, you can just select the "Center on Point Icon and pic the location the you want to rotate about. You probably need to then select the "Center Building Tool" on the right toolbar. Link to comment Share on other sites More sharing options...
CCCArchitect Posted August 7, 2014 Author Share Posted August 7, 2014 Assuming that you are using one of the overview cameras, then your camera will orbit around the center of the model. If there is something in your model that is way out in timbuktu, then your center will not be where you want it to be. Find it and fix it and your camera tools will work right. Also, you can always just use the full camera tool and the center of orbit is set by the camera focal point (where you stop drawing the camera). I have been trying to find an object out in space and unable to......any tips...I tried turning on all the layers and nothing pops up....I think it all started when I was experimenting with primitive solids???? Link to comment Share on other sites More sharing options...
Solution Joe_Carrick Posted August 7, 2014 Solution Share Posted August 7, 2014 OK, so zoom way out in plan view with all layers on and marquee select the areas outside your building. Delete anything that's found. Do this on all floors 0,1,2,3,4,A There's something out there someplace. Link to comment Share on other sites More sharing options...
KilgoreTrout Posted August 7, 2014 Share Posted August 7, 2014 Sometimes control-A will pick it up. Link to comment Share on other sites More sharing options...
ebdesign Posted August 7, 2014 Share Posted August 7, 2014 You can also isolate it by floor by using the floor camera & the "Fill Window" command. Once you've determined what floor it is on, it can be further isolated by turning groups of layers on/off & using "Fill Window" until you have it narrowed down. Kinda like a "Price Is Right" game. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 8, 2014 Share Posted August 8, 2014 Thanks....I zoomed out and it appears I my rotation point has somehow changed, the model rotates around some unknown point? is there a way to change how the mouse controls the rotation?? in 3D views the mouse controls are used depending on how the Rotation is set in 3D>move camera with mouse> Orbit/Pan/Dolly etc. the next option lets you do the same for the keyboard arrow keys. Link to comment Share on other sites More sharing options...
CCCArchitect Posted August 11, 2014 Author Share Posted August 11, 2014 Thank you all...had molding object out in space...attic layer Link to comment Share on other sites More sharing options...
