Automatic Callout label in Elevation
OkcDesigner
No I don't believe so but it sure would be great if it did and can't understand why it does not.  I do use the %layout.label% macro in the lower line to help keep things more consistent and it will read the page information where it is placed but is not really a direct link but has no way of fouling up that I am aware of.
When Elevations are created and saved they are automatically named in the Project Browser as:
  • Elevation 1
  • Elevation 2
  • Elevation 3
  • etc.
If you rename them as
  • E1
  • E2
  • E3
You can then put the %view_name% macro in a callout in the Elevation view.
Joe,  With your method is there a way of matching what the plan view camera call out displays for use in the view call out for the layout using macro's ?  So that the camera name or number and the layout page number is all automatic.
I assume the OP and I are facing the same issue placing the call out in layout but I assume you are placing the call out in plan and sending to layout. Is that correct ?
Joe,
Thanks but I rename elevations already to make cents to my human brain. IE the "Master Bath 1" and use your handy dandy Block for that and the scale...
Was trying to use Callout and not have view labels on in floor plan view.......
Chopsaw,
I actually do all my work in plan. Another one of those make cents to my human brain. Only thing i do in layout is titleblock, stuff... I do not even use labels in layout.
I just wish a program claiming BIM really knew how to give access to the BIM... Before anyone calls me out on the BIM statement. ART was the first time i recall hearing it!!! 1995ish
You can get the view name to appear in the callout even if you place the callout in layout.  It just requires a referenced context macro and an arrow connecting the callout to your layout box.  The layout box's automatic_label attribute is the view name.
MIchael,
I think you misunderstood what Marc is wanting.  He wants the Callout he places in the Elevation View to automatically reflect the Camera Callout in the Plan View.  That isn't possible with the current implementation of Cameras & Callouts.
It's something that's been asked for several times but currently can only be done manually - easy to make a mistake.
  • 1 month later...
On 3/10/2018 at 11:09 AM, Joe_Carrick said:
MIchael,
Not to mention a long and labourius process.  I spent 3 hours yesterday on a plan, adding callout references and checking, double checking and triple checking all this work.  I still found one error on the triple check.  Another designer showed me this in Revit Lite the other day, and it is all automatic.  I don't particularly care for using 3D glasses to naviage my designs if I need to spend hours on this type of work to ensure accuracy.
    30693
    mikedanderton
    mikedanderton
  • Similar Content
    • By ericepv
      Floor plans and renderings from a Rochester, NY based company available for remote work. I am a long time Chief user (X6 to X13) and have worked for many commercial and residential clients across North America. You can view samples of my work on my website, Houzz profile  or my YouTube channel.
      Please contact me directly at 585-441-5291 EST or by email: eric@epvisualz.com.
    • By DeLayDesign
      I've set up our walls to show demo'd walls to be dashed, but I'd also like that dashed line to show up in elevation as well.  Is there a way to do this, without moving the wall to a 'demo wall layer'.
      I suppose I could edit all the walls so that anything that isn't to be demo'd isn't associated with the layer it's put on (remaining solid vs. dashed); but is there a better way?
      I would also love for the siding/ brick, etc. to come in dashed as well if possible.
    • By Mardie
      Of Course on a deadline and never experienced this in 20 years!  HELP!  See attached.  Working on elevations.  Using exactly the same cross section elevation, but one is coming up as "Active Defaults" and one is coming up as "1/4" Defaults", there is not an option for "Active Defaults" in the drop down.  Creating havoc on Notes.  Have not idea how to fix this.  Thanks!  Mardie
    • By EngelsmaHomes
      Hi all,
      I noticed small angled lines that are commonly used to indicate glass on drafting drawings on elevations from Chief (see example photo attached). Is there a way to turn those 'ON' with a glass or reflective material? Or are those being added manually?
      Thanks for the help!
    • By Chrisdutch89
      I'm attempting to relocate a polyline solid in the "z" direction.  I drew the polyline solid for an elevation on the high elevation of a shed roof and it located on the low elevation.  Is there a way it can relocated to the high endOverview - 2.20.21.plan
